It is currently Tue May 21, 2013 7:58 pm
 Post subject: 550D sensor cleaning
PostPosted: Fri Nov 05, 2010 1:50 pm
Hello can someone give me some tips on how to clean a sensor properly instead of sending it to any local camera shop and get charge for about £40-60.
because when I look at my viewfinder there is this tiny black stuff a small hair i think or something else and it worries me so I want it to be removed.
recommended cleaning kit for cleaning a sensor.
EOS Photography
Image Image Image
I like simple, I like RAW, I like to learn more :)
PostPosted: Fri Nov 05, 2010 2:54 pm
That's not the sensor but the viewfinder housing!
Use a blower to remove dust, like you should do when your sensor is dirty.
PostPosted: Fri Nov 05, 2010 3:14 pm
anyhow my sensor has some small dusts and how can I get rid of this tiny thing that is sitting on my focus point?
EOS Photography
Image Image Image
PostPosted: Fri Nov 05, 2010 4:10 pm
here some youtube link talk about how to cleand the canon DSLR sensor.
another is speed test between Sensor Cleaning liquid Evaporation Speed Test.
http://www.youtube.com/watch?v=qi6S3jHA21w
http://www.youtube.com/watch?v=VR5sHflh ... re=related
Hope this might help. well i found some of this is quite useful. :)
Canon EOS 7D + Red Canon IXUS 300HS.
Canon EF 17-40mm f/4L,Canon EF 100mm F/2.8L IS USM.
Sigma 70-200mm F/2.8 APO EX DG OS HSM, Sigma 50mm F/1.4 HSM
Canon Speedlite 480EX II + Tripod+ B+W MRC (2x77+67), hoya HD UV (77) B+W MRC 77mm(CPL slim+10 ND).
PostPosted: Fri Nov 05, 2010 4:42 pm
If you see speckles in the view trough the viewfinder the dust IS NOT on your sensor. I dont know how you think a camera is built.... maybe like the Sony A33?
No, the mirror of your dSLR has some dust on it, simply use a blower.
PostPosted: Fri Nov 05, 2010 5:01 pm
It could be on the focusing screen as well, as is the case with my 50D. I have an annoying little speckle that won't go away :x
But in any case it's not on the sensor if you see it through the viewfinder. If you see it in live view though, then it could be
Canon DSLRs: 5D Mark III, 7D
My deviantART
PostPosted: Fri Nov 05, 2010 10:41 pm
so i just have to blow some air on the viewfinder and that tiny thing will be removed.
I will buy some cleaning materials tomorrow and clean my camera right away.
EOS Photography
Image Image Image
PostPosted: Mon Jan 17, 2011 5:16 am
IMO If I had a problem with dirt on the actual sensor I would not touch it with anything as it requires specialized cleaning and optically examining for imperfections.
But basic mirror, roof and viewfinder glass cleaning which is usually where the dirt is, is fine with a little bit of care and using proper camera cleaning gear.
PostPosted: Mon Jan 17, 2011 4:37 pm
I cleaned it already but theres some new dust or dirt so i'll clean it again using that specialised cleaning liquid with swab.
EOS Photography
Image Image Image
