It is currently Thu May 23, 2013 10:12 am
PostPosted: Sat Oct 30, 2010 6:17 pm
Had a quick search but didn't find anything.
I've got a Tonika 28mm f2.8 prime which is all manual.
Any top tips on how to get the exposure right or close, do i have to buy a light meter?
PostPosted: Sat Oct 30, 2010 7:06 pm
You don't need to buy anything, just check your histogram when reviewing the image, or use live histogram in LV mode (if your camera has live histogram ofc)
PostPosted: Sat Oct 30, 2010 7:22 pm
Hi Timmy
That's true the tools are there. Its a D90 so no live histogram.
I guess using live view i should be able to sort it out.
l'll give it go now i think.
PostPosted: Sat Oct 30, 2010 9:38 pm
If it's a D90 you are using, the only thing you can do is shoot and check histogram. Live view mode doesn't give a preview of the image (as opposed to canon's LV :()
PostPosted: Sat Oct 30, 2010 10:28 pm
There's a light-meter built in the camera!
That's the same scale as the EV mode in PAS, but in M it is the light meter.
PostPosted: Sat Oct 30, 2010 10:35 pm
The D90 doesn't meter with analog lenses
PostPosted: Sun Oct 31, 2010 2:09 pm
I didnt say it meters, my old MF lenses dont meter too with an adapter I have.
Just look at the exposure value meter. http://www.cameras.co.uk/cameraimages/c ... sation.jpg
There you could see the exposure metering with AF lenses, but in Manual it will work as a light meter.
PostPosted: Sun Oct 31, 2010 3:37 pm
Again, the D90 doesn't meter with non-CPU lenses, meaning there's no exposure value meter, no matter what you do
