agun wrote:
SolarSanction wrote:
big apertures are great for low light and you wouldn't be using it to its full potential if youre stopping light from getting in
I disagree for 2 reasons:
-Using a ND filter on a 50mm lens at an aperture of 1.8 is not pointless. It's useful in any situation that requires a
shallow DOF and a long exposure in bright conditions.
-You just
cannot use a 1.8 aperture for landscape photography (the main reason the OP wants to use it for). The picture would be completely out of focus because at F1.8 you get a
shallow DOFIn landscape photography everything needs to be in focus and to achieve that you normally use apertures smaller (Higher F number) than F8, regardless of the lens used and it's focal length.
Your first reason, being
true, doesn't really apply to this situation at all because, sunsets are usually almost considered lower than daylight conditions.
I apologize for the confusion, I was merely stating the general nature of this type of lens. I'm not saying that it's a rule not to use a filter with this lens, I'm just saying that you're not using the lens to it's full
potential under LOW LIGHT situations given that you're shooting anything BUT landscapes.
Nevertheless, I think we can both agree that the 50mm f1.8 isn't the ideal lens for this kind of shooting (or so I hope)
