It is currently Mon May 20, 2013 8:30 pm
 Post subject: Combination lenses
PostPosted: Tue Jan 19, 2010 3:33 am
Hi...
I am planning to buy a Canon eos 1000d. The kit lens is 18-55mm, which is about 3x. Is it possible to attatch a 200mm prime lens to the 18-55mm lens to get a 11.1x zoom? Or for that matter, can dslr lenses be joined in combination?
Thanks in advance,
Jinay.
PostPosted: Tue Jan 19, 2010 12:27 pm
Unfortunately no, you have to change the lenses to get both focal lengths. Look for zoom lenses such as the 18-200mm if you do want such a vast difference in focal lengths in one lens
PostPosted: Thu Jan 21, 2010 2:46 pm
What you can do though, is get a zoom lens that zooms to about 100mm, then use a reversing ring to mount a 50mm in front of it. Allows for some spectacular macros... :)
PostPosted: Fri Jan 22, 2010 9:11 pm
Definitely No. As Jeremy suggest, the 18 200 is a way to go :)
Soon.....Image
