It is currently Wed May 22, 2013 3:19 am
 Post subject: Bokeh
PostPosted: Thu Dec 03, 2009 5:46 am
I am now trying to prefect my bokeh and was just curious how to get good bokeh and a picture like this.
http://www.flickr.com/photos/mlephotos/2882136165/
(I didnt take this)
Im also wondering if I need to use manual focus to get my whole photo blurry like this one and some others ive seen.
I WANT TO KNOW THE SECRETS! :)
SonyA200 ~ 18-250mm ~ 50mm 1.7
http://www.flickr.com/photos/39243783@N06/
PostPosted: Thu Dec 03, 2009 6:50 am
here is a video workshop by Gordon Laing, Editor of Camera Labs....
http://www.dslrtips.com/workshops/How_t ... ield.shtml
And to take a photo like the one you have linked to:
1- put the lens to manual focus
2- use the closest focus point you possibly can (opposite of infinity)
3- use the largest aperture you can. (in your case f/3.5 or 5.6)
4- snap the picture
And Three tips for getting shallow depth of field
1- large aperture (f/2.8 and larger works best, larger meaning f/2.0, 1.8, 1.4, 1.2 and so on)
2- shoot telephoto. 70mm will provide you with a much better bokeh than 18mm.
3- distance from subject. the closer you are to your subject the more shallow the DOF. The further your subject is from your background the more it is knocked out.
Example:
Notice in this image I took earlier today...
1- I shot this image at f/2.2
2- I shot this image at 50mm not telephoto but on a cropped canon body its 80mm which is a sweet spot for portraiture.
3- I am very close to my subject, my subject is very far away from the background.
the perfect combination for shallow DOF (depth of field)
...hope that helps
Manfrotto 055CX3 + 496RC2
www.thomaslowe.com
PostPosted: Thu Dec 03, 2009 9:43 am
Like this?
Tomis described the smooth out of focus areas, but I think you wanted the...light dots.
These work in the same way Tomis described, but you need some bright points in the background (highlights). I used the sun reflecting of some other bikes. Postprocessing (contrast, curves) can further bring out the bokeh.
^that shot was shot with a 70-200 at I think 200 mm @ F/2.8.
PostPosted: Thu Dec 03, 2009 3:41 pm
Thanks tomis and citrus. I was talking more about the light dots. I will give this a go and try to practice with some christmas lights. :)
PostPosted: Thu Dec 17, 2009 10:10 am
when the light source (dots) in the background are out of focus, it shows up as a round dot in the your shot
pretty much like Tomis cover above.
Use lenses with Large aperture ( ex: f2.8, f2, f1.8, f1.4, f1.2 )
then place your subject some what close to the lens, the greater the distance of the background = the better bokeh
ex lenses are does these best are fast Primes lenses, 35mm, 50mm 85mm ..... etc
some bokeh example to demonstrate
1Image
f1.2
2Image
f2 i think at close as possible
3Image
f1.4 at close as possible
4Image
f2.8 at close as possible.
5Image
this is just making it out of focus a little.
Nikon D2h | Noct-Nikkor 58mm f/1.2 | Nikkor 35mm f/1.4| Nikon 85mm f1.4 |SB-600 SB-28 SB-28
" The best camera is the one that's with you" Chase Jarvis
Blog
