It is currently Sat May 18, 2013 8:47 pm
 Post subject: Aperture questions...
PostPosted: Fri Dec 21, 2012 6:22 pm
Okay this may be a stupid question but I have to ask because I just don't get it! I understand that the F number on a lens is the lowest it can be set. So a zoom lens like the Tamron 70-300mm f/4-5.6 would have a max aperture of 4.0 at wide angle, and 5.6 when zoomed into 300mm. But I see a lot of people who show pictures taken at F/8 to F/16. Does this mean there is no real minimum aperture size, or does the camera body limit this?
And lastly, let's say you have a 50mm 1.8 lens, but set the camera to F/11. Would the 1.8 lens give more light at F/11 than a 50mm 2.8 lens also set at F/11? In my mind both would have the same amount of light at the same F/stop, but I am probably wrong. I wanted to clarify this because I am about to buy some lenses and am debating on which direction to go.
PostPosted: Fri Dec 21, 2012 6:34 pm
Lenses do have a maximum f number they can be set to. This depends on the lens not camera. Most of the time it is not really important what this is, as you will enter a region of diffraction softening regardless of the lens.
In general, any lens set to f/11 will perform like any other lens set to f/11. However, be careful comparing fast lenses, with not so fast ones when close to their limit. For example, a 50mm f/1.8 lens used at f/2.8, will generally be "better" than a 50mm f/2.8 lens at f/2.8. In general, lenses get a bit sharper if you don't use them at their maximum but a bit below that.
