It is currently Wed May 22, 2013 4:04 pm
 Post subject: DIY backfocus fix.
PostPosted: Wed Mar 07, 2012 12:48 am
So I have a Sony a300 that had back focus. Its not under warranty so I decided to fix it my self. Turns out its pretty simple.
How many of you ever done this to your camera?
I'm not scared. :lol:
PostPosted: Wed Mar 07, 2012 8:22 am
I fixed focusing offsets by using the micro-adjust function :) Be so much easier if they put it in every body and not just higher end ones.
If memory serves me correctly, on the a300 isn't it done by some screws under a label on the bottom? Did you find it hard to dial in the right adjustment? And does it work well for all your lenses?
PostPosted: Wed Mar 07, 2012 10:26 am
Yes there are 3 screws on the bottom under the label. Did some focus test at 45 degrees and turned all the screws clockwise 1/4 turn.
Wash, rinse, repeat.
Took about 5 tries.
Hardest part was removing and setting back on tripod.
And good question about all lenses. Will get back with you soon on that one.
