It is currently Sat May 25, 2013 3:34 am
PostPosted: Thu Jan 10, 2008 1:08 am
Yeah, I know its weird. I want to know if there are any good ways of adding vignetting to your pictures without using photoshop. I have noticed that it gives a much more dramatic black and white image. I love shooting black and white so i try to make them as good as possible.
A guy I know uses a 5D and it is pretty bad on the vignetting maybe because he is using a Nikkor lens or something but I just want to know what the best way is.
I don't want it to be as blatently black like if I were using a circular fisheye but just darker around the edges. Not solid black. Here is an examples...
D200
5D
Film
Canon EOS 5D + 50mm f/1.8
http://flickr.com/photos/nathan_ward
PostPosted: Thu Jan 10, 2008 2:02 am
The Canon 5D is a full-frame, so vignetting is more noticeable than on an APS-C sensor. I assume you have the Nikon D200?
If you do want to enhance the natural vignetting on a lens, you can use a thick rimmed screw-on filter and the lens almost, if not, fully blown open on the aperture. An oversized lens hood could also increase vignetting.
Nikonian
PostPosted: Thu Jan 10, 2008 3:10 am
Yeah I will have my D200 in about 3 days.
I thought about the lens hood and getting a big but I need to think of a way to keep it on there. I also have tried putting multiple screw on UV filters and that helps too.
Anything else?
PostPosted: Thu Jan 10, 2008 3:19 am
I like vignetting too. I use lightroom to do it.
Graham
PostPosted: Thu Jan 10, 2008 4:03 am
yeah but I don't edit my pictures. I am not talking down to people to do but I prefer not to.
PostPosted: Thu Jan 10, 2008 7:06 pm
Just fix a cardboard with circular cut-out to your lens or the appropriate UV-filter.
You have to experiment a bit as the effect depends heavily on the lens...
PostPosted: Fri Jan 11, 2008 5:07 am
Or how about a lens hood that's too big!
PostPosted: Fri Jan 11, 2008 8:20 am
Any particular reason?
Personally I don't see the distinction between using a filter at the front of the lens or behind it.
