It is currently Mon May 20, 2013 12:48 am
 Post subject: New PC not running game
PostPosted: Thu Oct 25, 2007 1:46 pm
Hi - hope someone might be able to help me with this.
I recently has a new PC assembled:
Intel Core2 Duo E4400 2GHz
2GB RAM
nVidia GeForce 8400 GS 256MB card
XP Home SP2
I installed an original copy of SimCity 3000 ok but after clicking the shortcut, nothing happens and it doesn't run.
I'll get the min requirements off the box but I'm pretty sure the machine exceeds them.
Any idea's?
Thanks.
PostPosted: Fri Oct 26, 2007 1:02 am
Hmm...yeah your machine more than meets the requirements.
My first ideas are:
1) Game did not install properly, uninstall and try to re-install.
2) Video drivers are not compatible with the game, although this would generally result in some type of error message, it is worth considering trying other drivers for the 8400.
3) The software may need to be run in compatability mode, as sometimes with newer OS'es older applications that were very OS dependent didn't like to be run on newer OS'es, so right clicking the shortcut and running it in compatability mode for say, windows 2000 or 98 might just do the trick.
4) The shortcut may not work properly so go to the directory where the .exe file is to launch the game, e.g. C:\Program Files\Sim City 3000\SimCity3000.exe (or something like that) and simply launch the executable.
Thats just 4 things that it could be, but sometimes i've seen applications, no matter what i've tried, just wouldn't launch until I re-installed windows clean - hopefully that isn't the case here!
MY FLICKR!
PostPosted: Fri Oct 26, 2007 9:19 am
Thanks Daniel - will try your suggestions.
Canon EOS 400D, Canon EOS 30V, EF 17-40mm f/4L USM, EF 50mm f/1.4 USM, EF 70-200mm f/4L USM, Speedlite 430EX, Kenko & Cokin filters
