It is currently Thu May 23, 2013 8:29 am
 Post subject: network problem
PostPosted: Sat Oct 15, 2011 11:35 am
Hi There,
i've got a problem connection two computers to each other.
The internet didn't give a solution so I hope one of you can help me out, or point me in the right direction.
This is my setup:
- pc 1: A home build windows 7 computer with a clean install (english language)
- pc 2: A netbook with windows 7 starter, windows is as installed by the manufacturer (dutch language)
- Router: A modem/router (huawei) that I must use in conbination with my digital tv/internet/telecom service.
I set up both computers as a Home network using the Home Group option. Both computers now show up in each other windows explorer.
Then, on both computers, I go to a folder and right cliking on them I select sharing (read/write) with home group. After this the shared folders show up on both computers.
But now I get lost.
When I click on a folder shared by the orher computers, windows starts searching and comes up with a network error. Windows says it cannot access the path given.
As I mentioned earlyer I can't find a solution for it using google.
Please shine some light on to my problem.
www.pimvandevelde.com
PostPosted: Sat Oct 15, 2011 1:49 pm
Is there an error code?
D7000 and too many lenses.
PostPosted: Sat Oct 15, 2011 2:35 pm
No code unfortunately, I'm still searchin the internet and find that many more people have problems with the "easy" home group network.
Bu I can't seem to narrow it down. I've already shut off both my computers firewall's an virus protection (temporarely that is) to chef if thet caused the problem. But No. So it must be windows or my router.
PostPosted: Sat Oct 15, 2011 8:55 pm
did it asked you for some password? as i remember when i tried file sharing it asked me for some password, which i generated from another computer.
also try rename default workgroup for something else.
Canon AT-1, 50mm FD F1.8
Canon A430,
PostPosted: Sun Oct 16, 2011 7:37 am
Computer one gave me a password and computer 2 asked for it, so that's not the problem. I also changed the name of the workgroup like you said, but that made no change.
On the positive side, I now get an error code so I can use that to search the internet. 0x80070035.
Thank you for your info.
p.s. After all the suggested changes I again turned off my kaspersky firewall. And now I'm able to acces both computers. So now the question is, how do I set up kaspersky. But that is for after my vacation.
Thanks for the help
PostPosted: Sun Oct 16, 2011 10:39 am
not sure on your set-up but I only use the firewall in my router, all the others just get in the way.
PostPosted: Sun Oct 16, 2011 6:28 pm
I had begun with shutting of the kaspersky firewall and didn't get trough. After all the other tweaks I made I shut down the kaspersky firewall again and now I got trough. So I tweaked the firewall a bit and now I finally works.
I had to set the local network in kaspersky to a home setting instead to a public one.
Thanks to you all for the info provided.
