It is currently Wed May 22, 2013 1:18 pm
 Post subject: Windows 7 RAM Problem
PostPosted: Mon Jan 11, 2010 11:10 am
Hey, I'm running Windows 7 Professional 64-Bit and I have 6GB of Kingston HyperX RAM on my motherboard which is a ASUS P6T SE which can have 24GB of RAM, but Windows 7 is only saying there is 4GB of RAM, but when I run CPUZ is says I have 6GB. Anyone know what might be wrong?
mobile phone accessories
PostPosted: Mon Jan 11, 2010 12:45 pm
Check in your bios.
PostPosted: Mon Jan 11, 2010 8:24 pm
Yes, there may be a setting in the Bios to enable support for more RAM - check your motherboard manual.
PostPosted: Tue Jan 12, 2010 10:21 am
Are you sure you installed the 64-bit version of Win 7? A friend of mine just did the simple mistake of installing the x86 and not the x64 version (x86 being 32-bit) and that would explain why Windows can only see 4GB instead of 6GB.
Shouldn't be a BIOS setting problem, not on an X58 board anyhow and as long as the memory is discovered by the BIOS (which CPU-Z suggests) then it's a problem related to Windows.
Canon 500D, 18-55mm IS, 55-200mm IS, Nissin Di622
PostPosted: Tue Jan 12, 2010 10:07 pm
Yep, that occurred to me too - are you sure you've installed the 64-bit version? The 32-bit one will only see 4GB. Have a look at your system properties...
PostPosted: Mon Feb 01, 2010 1:23 pm
It's more than likely he installed x64. If he had installed x86 he would probably see:
Installed memory (RAM): 4.00 GB (3.00 usable)
PostPosted: Thu Feb 04, 2010 6:38 pm
I installed Windows 7 X64 on my Core 2 Box and it was saying 2GB installed, but theres 4. Very strange not figured out whats up with it yet.
MY FLICKR!
