It is currently Sat May 18, 2013 11:32 am
PostPosted: Sun Nov 07, 2010 8:21 pm
This post ended up quite long, so added a quick summary to get to the point at the start:)
The point of this post is to as understand what tools you use to build your websites? I have a few weeks left for the dreamweaver trial, at which point I will decide to buy or not. If in the meantime I find a better tool, then I will certainly try that too.
I have decided to rebuild my existing site, www.parisbyphoto.com as it is really not designed well and grew randomly as and when I went out and took photos that I found interesting. I was going to just reorganise and rebuild using the same tool, rapidweaver, which is easy to use but unfortunately, with that ease of use comes lack of real flexibility. So, I looked around for another tool and came up with dreamweaver.
To start get to grips with dreamweaver I built a new site, quite small but a good exercise, www.gigapixelparis.com. Basically, for this site I built a single template, marked some areas as editable so I can add a bit of descriptive text for each gigapixel image and made it possible to change the gigpaixel image being loaded etc. Each time I want to add a new gigapixel image, I should have to spend no more than 10 minutes adding it, which compared to working on Parisbyphoto will be a treat.
I will certainly enrich the site as it matures, but first I will add another 16 gigapixel images, some are nearly ready, some need to be taken when I get better weather.
Another thing I am working on is the gigapixel tutorial, which is nearly ready. It will be a pretty basic tutorial though; as I am pretty much just starting out with these gigapixel photos.
The rebuild of parisbyhoto.com is going to take months, especially considering I only have my spare time to work on it due to a full time job doing something to pay the bills! So if I am going to invest so much time, I want to use the right tool this time. With that in mind, I was wondering what tools other people use....this bit I added to the top as post too long...
I like most the split view in dreamweaver, which allows me to edit the site graphically or direct in the code, which is very useful. So any other tools that I would consider would need offer some similar functionality.
Thanks for your feedback!
http://www.parismetrotrash.com
PostPosted: Tue Nov 09, 2010 4:14 am
First step is to actually have a fairly concrete design before you open Dream Weaver.
Make a mockup of what you want the site to look like using pen and paper, photoshop, or inDesign. It is a lot easier to experiment with design ideas using these tools than it is working in Dreamweaver.
For the record: Everything I build is designed in either Photoshop or Indesign. I code the websites using vim (a fancy text editor). Technologies used usually include:
PHP
MySQL
Dwoo Template System
JQuery + a few plugins
Recent pics on flickr
Canon 500D, 18-55mm IS, 55-250mm IS, 50mm f1.8 II, 430exII
