It is currently Thu May 23, 2013 3:48 am
 Post subject: First Real Camera
PostPosted: Fri Jul 13, 2007 7:23 am
If everything goes right, I should have enough money for a Canon Digital Rebel XTi in a couple weeks. My last camera, which I rarely used, had under 3MP of resolution and is probably 6 years old. Will this camera be fine for use in a photography class in college (I plan on majoring in photography and journalism) or will I need to spend another couple thousand in just a year or two. Also, if the Digital Rebel XTi is good for a college photography course, what are some essential accessories for it? I was thinking about getting a polarizing filter and maybe a better lens, but I'm a complete novice when it comes to photography. Thanks for the help.
 Post subject: New XTi
PostPosted: Fri Jul 13, 2007 8:27 am
Congratulations on you decision to go with the Canon. If it isn't good enough for your photography class then change your class!
As far as choosing a lens upgrade I would suggest two things. Get advice from your tutors and fellow students not only about what focal length, zoom, aperture to choose but also about where you are likely to go in the future as far as camera bodies are concerned. If you plan to stick with Canon but eventually upgrade to a full frame sensor such as the 5D then if the budget permits choose an EF lens as the EF-S lenses are only intended for cropped frame bodies such as the XTi.
PostPosted: Fri Jul 13, 2007 10:24 am
You might like having an external flash unit ??
420ex or 430 got a number of 43 as "flash power" and teh built in only have 13.
Canon Rebel Xti (400D), EF-S 18-55, 50mm f/1.8, Sandisk Extreme III 2gb.
Http://cr4zyh3ad.sisimple.ca
PostPosted: Fri Jul 13, 2007 11:49 am
How important is flash for outdoor photography?
PostPosted: Fri Jul 13, 2007 4:18 pm
If you need to fill in gross shadows, e.g. for portraits against the light, you need a lot of flash power or a reflective setup with white cardboard, mirrors etc.
PostPosted: Sat Jul 14, 2007 2:48 am
as tombomba said !
PostPosted: Sat Jul 14, 2007 7:27 am
Thanks for the help, but right now it looks like I won't have the money to get a camera. Hopefully I'll have enough to get it before college.
PostPosted: Sat Jul 14, 2007 8:14 am
Don't despair! XMAS is approaching FAAAAAST :wink:
PostPosted: Sat Jul 14, 2007 10:20 am
I wish I got a thousand dollar gift for Christmas :D Do you know how much used XTis go for and if it's safe to buy a used camera?
 Post subject: Alternatives
PostPosted: Sat Jul 14, 2007 10:32 am
Don't despair! There have been a number of threads on such choices. Have a look at:
http://www.cameralabs.com/forum/viewtopic.php?t=815&highlight=350d
http://www.cameralabs.com/forum/viewtopic.php?t=728&highlight=350d
The Search link at the top of each forum page is a good way to find more. Just pick a model number one generation back from the current latest release from any particular manufacturer and browse through the search results.
As you will see, just because there is a newer model out doesn't mean that the earlier models are suddenly rubbish! Gordon has a number of excellent reviews on such legacy models.
Good luck.
PostPosted: Sat Jul 14, 2007 11:24 am
Would an older model be fine for 4 years of college? I doubt I'll have any money to upgrade when I'm in college.
PostPosted: Sat Jul 14, 2007 11:42 am
With 6 or 8MP cameras you can still make very nice photos.
It mostly depends on the eye+brain and not the lens+body :wink:
 Post subject: Eye+brain
PostPosted: Sat Jul 14, 2007 12:03 pm
Couldn't agree more but if in doubt do get in touch with your intended college and get some feedback from them.
