It is currently Sun Jan 22, 2017 8:12 am
PostPosted: Tue Jan 07, 2014 6:53 am
Help! Help! Yelp!
Upgrading from a PNS and confused between Nikon D5100, D 5200 and D 7000.
D5100 has 11 AF points and an older version of sensor. But how much does these points matter in practical life photography?
D7000 has semi weather proof body, internal AF motor, 39 AF points but no HDR mode. How to shoot HDR mode in D7000?
D5200 do not have weather proof body, no internal AF motor, 39 AF points but HDR mode.
Is the price difference between D5200 and D5100 justified for use of both in real life photography? Any considerable difference in image quality?
Does having a weather proof body and an internal AF motor in D7000 makes it a better contender than D5200 in real life condition? any considerable difference in image quality?
I will be using my camera to shoot birds, sunsets, night sky, stars, moon, floras, macros, landscapes, might even mount the cam on bike's fuel tank to shoot a video of speedometer.
Oh yes any considerable difference between video modes of these three?
If any other camera suiting my need then please do suggest.
I don't want to invest more than INR 70k in camera plus lens at present.
Please do not suggest me to buy nikon 55-300mm lens, I have already shortlisted nikon 70-300mm VR lens but confused between tamron 70-300mm and nikon 70-300mm.
And recently I saw a deal "http://ahmedabad.quikr.com/Nikon-D7000-…
Any suggestions weather to go for this deal or not?
and "http://ahmedabad.quikr.com/Nikkon-24.1-… deal.
Kindly put up your valuable suggestions. Gracias!!!
PostPosted: Tue Jan 14, 2014 9:56 pm
For the record, I've only used Nikons a few times but I don't imagine the most of the principles and realities are significantly different from those in Canon. Some of my answers are speculative but based on my experience with other cameras.
In some cases, fewer AF points can work more quickly though it can be at the cost of accuracy, particularly with moving subjects as of the 11 AF points, there's a single cross-type, which is faster and more accurate.
I'd imagine you just need to set your exposure bracket for an under-exposed, correctly-exposed and over-exposed shot. I'd be surprised if the D7000 doesn't have this.
Only you can answer that but you'd need to be more specific on "real life photography". For what I shoot, the D5200's AF (on paper) alone would persuade me to buy it over the D5100 but since you said your photography will consist of slow or still subjects, you may not benefit enough from the D5200's AF advantage to warrant spending the extra money.
As one succeeds the other, I think IQ differences are small in favourable lighting conditions if all else is equal but noise management in low light shooting may be improved in the D5200.
Again, you need to be specific about what "real life conditions" are. You could be on the Mediterranean coast of Turkey in the Summer where you're no better off having weather proofing than not but you could be in the Ardennes Forest being rained on constantly; both conditions are "real life" ones I've been in myself. If you're likely to be in rainy or dusty environments, the D7000 is at an advantage to it would be remiss not to have a rain/dust cover with either camera.
An internal AF motor makes the D7000 compatible with all AF lenses using the same mount, giving it a wider choice of lenses.
In most cases with contemporary DSLRs of the same sensor size, differences in IQ are far more apparent in the lens you use rather than in the body. Differences in IQ will probably be marginal though being newer, the D5200 may have less or at least less ungainly looking noise in low light.
srvkmr wrote:
...might even mount the cam on bike's fuel tank to shoot a video of speedometer.
It's obviously your money but are you sure you want to take such a risk? This sort of thing usually calls for using an action camera such as a GoPro. I'd imagine there are more options for mounting such cameras on your bike's fuel tank as well.
CSC: Canon EOS M3
