It is currently Tue May 21, 2013 4:10 am
PostPosted: Mon Dec 12, 2011 10:54 pm
in several of the low-end point & shoot cams, there are choices under the "P" mode, e.g. ISO setting. as i read that the low end cameras distort the image when the ISO is set too high, am not understanding how change of ISO "sensitivity" affects the camera sensor operation.
PostPosted: Tue Dec 13, 2011 1:39 am
As ISO goes up - so does the noise. The reason for increasing ISO is to reduce the shutter speed, but it does come as a cost of the aforementioned noise.
Trevor Harris
Nikon D200
SB-600
YN-560 II
YN RF 603 x 4
Tamron 17-50mm f/2.8
Nikon 50mm f/1.8
PostPosted: Tue Dec 13, 2011 6:32 am
When you increase the ISO you increase the signal output from the sensor, and that includes the noise from the electric charge running through it.
Here's an analogy: For a P&S with its tiny sensor it's like trying to push massive sound (lots of megapixels) through a tiny speaker (small sensor). The result will not be very clean. The smaller the speaker the more pronounced to undesired noise will be
Canon DSLRs: 5D Mark III, 7D
My deviantART
