It is currently Thu May 23, 2013 10:58 pm
 Post subject: g3 or pl-3
PostPosted: Fri Dec 09, 2011 8:56 pm
I already have a superzoom canon sx40 and it takes a descent video so Now I am looking for a good still photo camera thats easy to carry.
I was going to get lumix g3 with 20mm lens but I now see olympus pl-3 with 17mm lens kit for about the same price as g3 with a kit lens which i don't intend to use very much.
g3 kit with 14-42mm $599. 20mm. $350 --- $950
pl-3 with 17mm -------------------------------- $650
I was wondering greater pixels, built in LV and a kit lens are worth the price difference. You get in camera image stabilization with pl3 so does it make a huge difference taking pictures with prime lenses?
What do you guys think?
PostPosted: Sat Dec 10, 2011 12:45 am
On one hand, situations in which one would need IS when using a short/wide and fast/bright prime are relatively rare. On the other hand, note that, at f2.8, the Oly lens is more than a stop slower than the f1.7 Pany lens.
Greater pixels, probably not. The advantage of a built in View Finder--I'm assuming LV is a typo--is largely subjective, except in bright (day)light. So how often do you use the VF on the sx40 vs the LCD? And the advantage of the kit zoom would largely depend on how much freedom/room you have to move forward/backward in your normal shooting environments. (You could try setting your sx40 to 35-40mm (35mm equiv.) and (re)framing your shots .)
HTH - Mark
