It is currently Sat Jan 21, 2017 3:33 pm
PostPosted: Thu Sep 13, 2007 6:44 pm
Hi everyone,
I'm making the move into DSLR photography and would like some advice as to whether I should go for the D80 with the 18-70mm (and probably purchase the 70-300mm later), or the 18-135mm for a more general purpose zoom. I'm sure it depends on the photographer but if I were to go for the first option, would it be realistic to keep swapping the lenses for the extra reach or would it be less of a problem than I think?
Price is not an issue and any feedback would be much appreciated.
PostPosted: Thu Sep 13, 2007 7:03 pm
Hello Markh, and welcome to the Camera Labs forum!
Weeeeell, if price is not a problem, why not go for the Nikon VR 18-200mm? It gives you lots of reach plus is stabilized - invaluable!
D810+assorted lenses
PostPosted: Thu Sep 13, 2007 8:08 pm
This is an option I am considering and I would prefer a single lens. I will probably go for the body and the 18-200mm VR separately but there's just one thing: is there any significant loss in genera quality, given the fact that the lens has such a long focal length?
PostPosted: Thu Sep 13, 2007 8:16 pm
You should at least read the "verdict"-page on Gordon's kit-lens-comparison here: http://www.cameralabs.com/reviews/Nikko ... roup_test/. The 18-200mm came out pretty good!
PostPosted: Thu Sep 13, 2007 10:20 pm
Hi Markh, you'd think the 18-200mm VR may be compromised due to its long optical range, but it's actually very very good.
Have a look at the results and Gallery pages in our review here:
http://www.cameralabs.com/reviews/Nikkor18200mm/
If you want a single lens to do it all and can afford it, then yes, it's the model to go for.
If you want a twin lens solution, then go for either the 18-55mm plus 55-200mm VR for a budget option, or the 18-70 plus 70-300mm VR for the quality option. If you're going for the D80 though, I'd sway towards either the 18-70 plus 70-300mm VR or the 18-200mm VR if you can afford it.
The 18-135mm is a really nice option as a budget single lens solution, but if you have a higher budget and or don't mind carrying two lenses, there's better choices.
PostPosted: Thu Sep 13, 2007 10:45 pm
As to the Nikkor VR 18-200, look here, here and here to see how it looks when attached to a Nikon D40X (which is identical, on the outside, to a Nikon D40).
