It is currently Sat May 25, 2013 2:53 am
PostPosted: Fri Sep 03, 2010 11:31 am
Ive read somewhere that class 6 will be ok, but cant find any other info to find out which class i need?
i dont want to fork the money out for a 8gb sdhc Class 6 if the camera can only buffer at class 4.
any help is greatly wanted,
thank you
neil
Amateur, always learning!
PostPosted: Fri Sep 03, 2010 3:08 pm
Hi Neil. It kinda depends on what you do with your camera.
Do you shoot in RAW or use continuous mode?
If not then Class 4 should be fine.
D7000 | 24-70mm f2.8G ED | SB-910
Lightroom 3, Photoshop CS5, Capture NX2
PostPosted: Sat Sep 04, 2010 8:51 pm
Also, if you want to film videos and take images at the same time, you'll need to dish out even more dinero and go with a class 10.
PostPosted: Sun Sep 05, 2010 2:07 am
The class rating is a load of BS imho.
I have class 4 cards that outperform class 6 cards, so you can't trust the rating.
Also, I've found that some cards don't work well in cameras for whatever reason, despite working well on the PC when tested at read/write speeds of close to 20MB/s, yet in my 500D I can't record more than a few seconds of video and then the camera stops.
Toshiba makes good cards imho and I'm using a SanDisk 20MB/s "HD Video" card now as I got a good deal on one. It's only a class 6 card, yet it perform better than the class 10 spec. However, it doesn't meet the 20MB/s rating on the card, although I guess 19MB/s isn't too bad.
Canon 500D, 18-55mm IS, 55-200mm IS, Nissin Di622
PostPosted: Mon Sep 06, 2010 11:53 am
The class rating simply refers to the minimum guarenteed write speed of the card. A Class 4's minimum write speed will be 4Mb/s, a Class 6's minimum write speed will be 6Mb/s.
