It is currently Tue Jun 18, 2013 8:44 pm
 Post subject: SD Memory card death
PostPosted: Tue Mar 02, 2010 5:15 pm
Yesterday i was going to use my 500D but when i turn it on the card activity light stays on for much longer than usual,
when the screen comes on it says: "card cannot be accessed. reinsert/change the card or format card with camera".
when i try to format the card with the camera i get a message that says it cant format it and to change the card.
the SD card does not work in the cardreaders in any of my computers either.
the card also hasn't been out of the camera since i got the camera in october last year, but i did try to clean the contacts on the card to no avail.
so is it possible for a memorycard to die overnight for no obvious reason?
it was a Transcend SDHC 8GB class 6 card.
DeviantArt
Canon 1D MK3, 1x580EXII, 1x430EX
Canon 50mm 1.4 USM, Canon 100mm F2.8 USM
Canon 70-200 F2.8 L IS II, Canon 16-35 F2.8 L
Sigma 300mm F2.8
Canon Pixma PRO-9000 MKII
and a 17-40 F4L in a hundred little pieces
PostPosted: Tue Mar 02, 2010 7:46 pm
when flash memory dies it just dies. check the contact of the card to see if they're not worn out if they are you might be able to save it, if the flash memory died, you are screwed AFAIK.
Check out: http://www.eagle1337.deviantart.com/
Camera: Canon Rebel T1i
Lens: Tokina 11-16mm f/2.8, Sigma 17-70mm OS DC HSM f/2.8-4, ef-s 18-55mm IS, ef-s 55-250mm IS. EF 50mm F/1.8
Tripod: Giottos MTL9351B with a MH 5001 head.
Bag: lowepro Slingshot 202 AW. Cards: Sandisk Ultra 2, Lexar MicroSDHC.
