It is currently Sun May 26, 2013 2:37 am
PostPosted: Mon Dec 07, 2009 1:37 pm
hello guys im new to this forum , i have sony DSC h9 and im planning to buy a 16Gb memory card however im not sure if its competible with my camera or not, can anyone comfirn this,can i use 16GB card with this camera?
thanx
PostPosted: Mon Dec 07, 2009 1:45 pm
Welcome to the forums!
Any memory card over 2 GB is SDHC (high capacity) memory. This should point you in the right direction. Check the manual for SDHC compatibility (I won't chew your food for you) ;)
PostPosted: Mon Dec 07, 2009 3:36 pm
Except it's a Sony camera, so it takes Memory Stick Pro Duo. 16GB should be fine, bit Sony themselves don't seem to have tested anything above 8GB with it.
Quote:
Memory Stick PRO™ Media Compatibility : Tested to support up to 8GB Memory Stick DUO PRO media capacity.
http://www.sonystyle.com/webapp/wcs/sto ... ifications
Canon 500D, 18-55mm IS, 55-200mm IS, Nissin Di622
