It is currently Thu Jun 20, 2013 4:34 am
PostPosted: Wed Nov 26, 2008 10:00 pm
:D hi there, i have just bought a sony a 300 , and now im wondering about wich card is the best for it. :roll:
i have it set for raw, and i like fast continuous shooting, so wich type of cards should i go for? memery stick or compact flash? and what brand of card, you know, extreme or ultra, or what else they are called ?? :( :shock:
im not that good at cameras yet, or spelling,, so bare over with me :wink:
kind regards daniel from denmark
PostPosted: Wed Nov 26, 2008 10:34 pm
i didn't realise the A300 took CF cards. I actually would've though that it would be memory stick being sony and all.
PostPosted: Wed Nov 26, 2008 10:48 pm
The native format is CF. It'll only take the small memory sticks with a CF adapter so I'd consider that rather pointless unless you have the memory sticks already.
In my A350 I've used Sandisk Extreme III and IV. Can't say I notice a speed difference between them in the camera.
PostPosted: Wed Nov 26, 2008 11:34 pm
how many fps does that DSLR shoot at? You'd be hard pressed to notice a difference unless we're talking 5fps and up, in which case the buffer would empty faster.
Unless we're talking transferring images to the pc, in which case if you had a firewire 800 cf reader, the IV would transfer faster.
PostPosted: Wed Nov 26, 2008 11:51 pm
The A300 goes up to 3fps, which is fine with jpegs but the buffer fills rapidly in raw.
PostPosted: Thu Nov 27, 2008 8:36 am
:D :D wow!! i didnt think that there would be help allready !! thanks :D :D
well i use the cf cards, but i i also have a memory stick ( i have a sony camcorder ) but a think that i will go out get me a sandisk extreme lll then, :) and then mayby set the camera for jpegs instead of raw, cause i think it "thinks" allot every time i take pictures, but ok, i only got it yesterday :) so i still need to find the optimal settings and all .
so thanks allot guys :D youve been very helpfull.
i think im going to use this forum again.
thanks :D :D :D :D :D
