It is currently Fri Jan 20, 2017 12:59 pm
PostPosted: Thu Oct 01, 2009 1:27 am
B+W 77mm Circular Polarizer MRC Filter $145
B+W 77MM Circular Polarizer Slim Mount Multi Coated Filter $169
Hoya HMC - Filter - circular polarizer - 77 mm $169
Well I never thought I would spend this much on a filter but I'm going on a trip, and I'm going to use step up rings for now on soo, I am hoping investing in a good polarizer is a good idea.
So any suggestions, recommendations, things to look for and lookout for. But I need to order one next week.
thanks your comments are a big help. I'm used to just buying a $30 tiffen :oops:
PostPosted: Thu Oct 01, 2009 9:44 pm
I can only speak for the Hoyas, as those are what I use - never had any problems with them, esopecially the HMC versions.
Don't forget to shop through our partner stores if you want to support us!
Thanks!
PostPosted: Fri Oct 02, 2009 3:42 pm
thanks for the reply Gordon, I thought I put in in this section I was in a hurry, wonder where I put it Landscape?
I just made to orders last week and went through the site, I'll do the same on this one.
anyone else? I had my eye on the B+W just cause its a tad cheaper. Most of these higher end ones should be fairly thin for wide angles shouldn't they?
PostPosted: Tue Oct 06, 2009 1:11 pm
man, just gordon on this one, Maybe I should of posted:
"what polarizer do you have, and would you buy again?"
