It is currently Sun May 19, 2013 9:45 pm
PostPosted: Mon Jul 14, 2008 5:55 pm
i use this printer for my print outs (kinda obvious....) but i have the problem where all the photo printouts are pretty bad. i select a appropriate paper type but the photos are always slighlty red, ie the colour balance is worng. after messing around with it for a while, i still cant get it right. any suggestions or profile changes that could be made, because the on-screen (monitor) images are all perfectly okay, just the printer that screws them!
Help?
Nikon D80
AF-S 18-135mm f3.5-5.6 Nikon {} AF 50mm f1.8 Nikon {} AF-S 70-300mm f4.5-5.6 VR ED Nikon {} Nikon AF-S 105mm VRII f2.8 Micro ED N
MB-D80 battery grip {} 4GB Sandisk extreme SDHC {} Manfrotto 109xb & 804rc2head {} Lowepro Primus AW {} SB800
Flickr: http://www.flickr.com/photos/27747651@N04/
PostPosted: Mon Jul 14, 2008 10:33 pm
have a good read of this ...... http://www.colourmanagement.co.nz/index.php ...... it will help you understand colour management
PostPosted: Tue Jul 15, 2008 8:58 am
thanks for that, still need to work out how to change it here though!
Nikon D80
PostPosted: Wed Sep 03, 2008 6:11 pm
Hi, i'm having the same exact problem with my canon pixma i4500. I set the settings to high quality and glossy paper and all that stuff and every time i print the photo comes out dark and always has a redish/purplish tinge to it but on the monitor it looks perfect. I've sent the picutres i'm printing to my friends and they all say that it looks fine to them so i'm guessing my monitor calibration is fine so what else could cause this?
I've noticed when changing the printer settings they don't actually seem to work? for instance i tried playing around with the colour settings which did nothing. So i set the printer settings to print the photo in sepia tone but it came out as normal. Anyone got any help for us?
Thanks,
Shane
Nikon D300, Nikkor 70-300mm VR, Sigma 10-20mm, Manfrotto055ProB / 808RC4.
PostPosted: Wed Sep 03, 2008 10:42 pm
I don't know for certain the cause of this, however I have just ordered the ip4500, so any solutions may well be relevant to me if I have the same problem.
I have heard a lot about people having difficulty printing from photoshop.
I have also read on another forum that somebody else had the same problem and put it down to canon's pigment ink causing a reddish colour on some papers (the ip4500 has both dye and pigment black ink cartridges). One solution suggested that selecting photo paper in the print options would cause the printer to use the dye ink rather than the pigment ink, thereby solving the problem. Have you tried this? (This may not be the problem, but it's worth a shot, right?)
I hope that helped!
Olympus E-510 | ED 14-42mm 1:3.5-5.6 | ED 40-150mm 1:4.0-5.6 | 35mm 1:3.5 Macro | Giottos MTL8361B & MH-5001 3-way head | Lowepro Orion Trekker II bag
http://www.calummacnab.com
PostPosted: Wed Sep 24, 2008 4:47 pm
My printer has arrived and I had the same problem at first. I then went into the printer settings and changed the colour/intensity from auto to manual then clicked set and changed magenta to -15. This solved the problem.
PostPosted: Wed Sep 24, 2008 5:43 pm
Ah ok great i'll try that. I knew there wasnt really much to the problem. I think also if i use proper cannon printer paper it might help. What paper are you using?
Shane
PostPosted: Wed Sep 24, 2008 5:54 pm
Cheap glossy paper off ebay :D called "Ice Pro Duo".
 Post subject: You Can Canon :-)
PostPosted: Wed Sep 24, 2008 8:19 pm
Hi guys,
I shift currently from Epson to Canon iP 4500 and
got the same problem with dark reddish colors.
so, before touching color sliders as this are "fragile" staff,
try to solve it with sliders "Contrast" and "Intensity" down there...
I did this way.
best,
Canon 40D, 17-40/4 L, B+W UV normal; canon-50/1.4
PostPosted: Wed Oct 22, 2008 11:51 pm
Well people, I have a Canon Imageclass MF4270 Black and White Printer scanner and it is super fast (21 rpm) I love it except its black and white. Can anyone recommend a similar Laser printer which can print as fast but in Color? I really need your help. What Brand and model has the fastest Color Laser Printer w/ scanner? Any helpful recommendation would be greatly appreciated.
CD/DVD Printers
