It is currently Wed Jun 19, 2013 7:29 am
PostPosted: Fri Aug 03, 2007 12:56 am
Hi all,
I have a Canon Pixma IP4200 printer and I'm happy with the prints it eventually produces but......I'm constantly wasting paper and ink because I have to play around with the brightness of an image before it prints the same as it looks on the screen. Another odd thing is that the level of brightness I have to add isn't consistent either. Sometimes 10 (think it's percent) and sometimes even as much as an increase of 50 before the print looks the same as how I see it on my monitor. That isn't normal is it?
I've been through the software that came with the printer and it has loads of tools for cleaning the nozzles and making sure they're aligned etc., but there is nothing about calibrating it to the monitor.
Does anyone know of an easy guide on how to sort this out or any software I could download that would do the job?
Thanks,
Mark Amy Photography
PostPosted: Mon Aug 06, 2007 9:11 pm
Look out, Mark!
One of the major probs with comparing prints and monitors is ambient light: The color and strength of the light influences heavily the way you appreciate your print.
I find incandescent light makes my prints dull and redish. I would not optimize for that. Although one can argue then, that if you have an exhibition somewhere with incandescent light, you should adjust your prints to look optimal under that conditions. ((Zorro - you're listening?))
When I compare prints I prefer bright daylight, no direct sun, close to a window. As your monitor is bound to be in a slightly darker place, produces his own light and has a constant color-temp it's always a challenge to compare.
So before you adjust your printer-driver and what have you, first go find a way to have stable lighting to judge your prints by!
B.t.w.: Which SW are you printing from?
PostPosted: Sat Dec 08, 2007 1:51 am
You also need to calibrate you monitor and your printer.
Otherwise you will never get it how it should be.
Otherwise, send them to the local photo-lab.
