It is currently Mon May 20, 2013 8:38 am
PostPosted: Mon Aug 04, 2008 11:30 pm
For some reason, I cant view thumbnails in any folders I open - I just see the irfanview icon for all associated image files! Regardless of which 'View' I choose, there is no preview of the images.
I like Irfanview, as it so quick to open and display images, but it is starting to get on my nerves a bit now....
Any ideas on how to rectify this - or any (similarly fast) alternatives to Irfanview?
Thanks
PostPosted: Tue Aug 05, 2008 12:29 am
I sometimes use Faststone (freeware) to quickly view images. It has some basic editing and conversion capabilities too. I haven't used Irfanview in Vista (only XP) but I'm temporarily on a Vista PC and I downloaded Faststone (short download) to have something other than Microsoft Photo Editor. :P
Give it a go and see what you think.
PostPosted: Tue Aug 05, 2008 9:55 am
Hi Rex,
I have IrfanView 4.1 running here under Vista x64 and don't have that problem except, of course, when the View Preference is set to small icons. Maybe it would be an idea to uninstall IrfanView to restore the default Vista associations and then install IrfanView once more. The latest version is 4.2 and can be found here.
Here is a list of the changes in v4.2
    There were numerous changes here are only the more important things.
    Version 4.20 ( - CURRENT VERSION - ) (Release date: 2008-07-16)
  • Basic Unicode support added (Properties->Misc 1, thanks to Christophe
  • New zoom options; improved relative zoom (Properties->Viewing)
  • Thumbnails can be sorted manually using drag/drop
  • GIF animations can be played in fullscreen/slideshow mode
  • New Advanced batch options: Fine rotation, Blur, Median ...
  • Option to show TIF Annotations created by Kodak Imaging Properties->Viewing)
  • New JPG save option: Set file size (PlugIn: thanks to Lucian Sabo)
  • New save menu: Save for Web (PlugIn: thanks to Lucian Sabo)
  • New thumbnails options to disable or configure info text on mouse over
  • New edit menu: Auto crop borders (remove outside lines/rows of same color)
  • New feature in Canvas dialog: negative border sizes are allowed (border crop)
  • New option in Capture dialog: Capture desktop on current monitor only
  • New options in Custom selection dialog: Set custom ratio; Save values
  • New slideshow option (window mode): Set window position
  • New Fullscreen display options: Fit to screen width/height (Hotkeys: 5/6)
  • IPTC data in TIF files can be showed (no editing yet)
  • Fixed Thumbnails crash on multi core CPUs
  • New command line option for EXE Slideshow: /window=(x,y,width,height)
  • Option to set Status bar text using placeholders (Properties->Misc 3)
  • Option for proportional paste into selection (Properties->Misc 3)
  • Support for EXR format (PlugIn)
  • Support for MAG format (MAKI, Formats PlugIn)
  • Default display option is now: Fit only big images to desktop
  • Expanded Copy/Move dialog (4 more folders)
  • New Edit menu: Maximize and center selection (hold CTRL to center only)
  • New option in Edit Palette dialog: Click on image to find color index
  • New Thumbnails menu: Remove selected thumbs from list, Hotkey: Ctrl+Del
  • New Thumbnails menu: Save selected files names as TXT
  • New Thumbnails menu: Start Panorama dialog with selected files
  • The Enhance/Correct colors dialog can be resized/maximized
  • Enhanced TIF-LZW saving with 24 BPP images (smaller files are created)
  • New command line option: /jpg_rotate=(...values...) JPG lossless rotation, see i_options.txt for examples
  • New command line option: /transpcolor=(r,g,b) Set transparent color: can be used for GIF/PNG/ICO saving
  • New Hotkey: SHIFT + F = Fit only big images to desktop
  • New Hotkey: SHIFT + W = Fit images to window
  • New Hotkey: NUM-PAD 5 = Scroll to image center
  • New Hotkey/Menu: CTRL + N = Open current file in another IrfanView window
  • New Thumbnails option: Auto scroll during creation
  • New option in JPG IPTC/Comment dialog: Append text to old text
  • Scan dialog: 'Skip existing files' works also for multipage TIF files
  • Several PlugIns are changed/updated, please install the newest versions http://www.irfanview.com/plugins.htm
  • Some minor bugs/features fixed/added (scrolling)
P.S. I've just installed 4.2 and plug-ins over 4.1 with no issues except the need to be in the Administrator account during installation.
PostPosted: Tue Aug 05, 2008 1:14 pm
Thanks for the replies guys....
Mark - DL'd the prog and 1st impressions look good if I cant sort out Irfanview......or even if I do!! Hmmmmm
Bob - I'm using 4.2 atm....kinda hoped it might sort out the issue by updating from my older version (but no joy... :cry: )
I'll try uninstalling it as you say - see if that does the trick. It was going to be my last attempt to rectify it anyhow, but after trying Marks recomendation for a couple of mins, it looks promising if it won't 'un-glitch' itself :)
PostPosted: Tue Aug 05, 2008 1:49 pm
Does it change if you uncheck JPG (and JP2 too perhaps) in Options>Properties/Settings>Extensions ?
Ben
PostPosted: Tue Aug 05, 2008 3:07 pm
Well I sorted out the issue with the thumbs not displaying....it was a checkbox in Folder/Search options ticked - "Always show icons not thumbnails"!! Easy when you find out the culprit - can't remember ever checking that option but I guess I must've at some point (prolly after one beer too many one night... :D )
But thanks to Marks suggestion, I now have a new default image viewer.....thanks Mark - cracking little prog - and best of all, like Irfanview it's Free :P
It's deffo worth a donation to the devopers - I always like to show appreciation with a donation for worthy software - and this IS one of those cases.
Thanks again for the pointer :wink:
