It is currently Sat May 25, 2013 10:29 pm
 Post subject: Noise Ninja
PostPosted: Sat Aug 02, 2008 2:22 pm
Having a sony a100 the one thing this cam is not so good at is noise at ISO 800 + so I have heard of Noise ninja.
Has anyone used or has this software, what is it like?
What would be the best way to ue noise ninja with adobe lightroom which is what I use for my workflow?
PostPosted: Sat Aug 02, 2008 3:00 pm
I use Noise Ninja but have tried a few others as well, it's definitely the best. The easiest way to get it to work with Lightroom is to go into the preferences and set noise Noise Ninja as the external editor. You can only have two though, and I think PS is fixed as the main editor so if you've already got an external editor then you will have to replace it.
OR
Right click on image -> Open in Finder -> Open with Noise Ninja
Graham
PostPosted: Sat Aug 02, 2008 4:35 pm
Yeah, I've used Noise Ninja on a few images and it does a fantastic job. The shot below was taken at 1600 ISO. It's as good as noise free after processing it with Noise Ninja. Obviously there is still some noise but nothing that perceptible unless you look very closely. It did smooth out the texture of the wall on the main building but I can live with that.
PostPosted: Sat Aug 02, 2008 6:47 pm
grahamnp wrote:
... and set noise Noise Ninja as the external editor. You can only have two though, and I think PS is fixed as the main editor so if you've already got an external editor then you will have to replace it...
you can have many more external editors... setup them up as presets in 'edit'-->'preferences'-->'external editing' then in the 'additional external editor' sub-menu select 'choose' button next to 'application', find the application and select 'ok', then select the 'preset' drop-down menu and select 'save current settings as new preset'... name it anyway you wish... the to use the presets you created simply right click the image, select 'edit in' and choose the preset (external editor) you wish to use :wink:
PostPosted: Sat Aug 02, 2008 8:24 pm
I also have the A100, and yeah the noise problem really causes some problems. I get bad noise at ISO 400 occasionally :lol:
But to help, I also use Noise Ninja. It's a fantastic little program plug-in that I can't live without :lol:
I use it on every image. Due to the lens that I use when I do more close-up shots, I lose a lot of sharpness. (Not the best lens :lol: ) So in Camera Raw, I need to boost sharpness a lot, which in turn will cause the noise to be more visible. So to fight this, I then run it through Noise Ninja and continue editing, and my final step is to do one more light noise removal through the Ninja :wink:
-Blog- || -My Flickr-
PostPosted: Sun Aug 03, 2008 2:28 am
I use it too, it does an amazing job.
It can save you from disaster :D
40D, 28-135 3.5-5.6 IS USM, 50mm 1.8 II
4GB Extreme III
My DA || My Flickr || My Metroflog
PostPosted: Sun Aug 03, 2008 10:30 am
Hi Thomas,
Lightroom only lets me use 2 external editors, one of which is PS and cannot be changed. I know the other one can be chosen from the list of installed programs and what I have mine set as Photomatix. What I was trying to say was that if I wanted to use Noise Ninja as my external editor, I would have to replace Photomatix as I don't have anymore "slots".
I don't see any options for presets or the ability to add more editors. Am I missing something? :?
Graham
PostPosted: Sun Aug 03, 2008 12:23 pm
i have three external editors setup through lightroom... just follow the instructions i posted above
PostPosted: Sun Aug 03, 2008 12:44 pm
I use noiseware pro, and Nik software's Dfine ; plugins for photoshop. Both work very well.
PostPosted: Sun Aug 03, 2008 12:49 pm
Should Noise Ninja be used to improve noise before editing the image (croping, colour etc..) or after these alterations have been made?
PostPosted: Sun Aug 03, 2008 1:10 pm
I use the noise removal plugin BEFORE the editing.
PostPosted: Sun Aug 03, 2008 2:24 pm
I'd say after the editing.
Why? Noise reduction will always remove some of the detail in the image no matter how good the NR is.
Graham
PostPosted: Sun Aug 03, 2008 2:53 pm
To be frank, it doesnt really make that much of a difference, see for yourself. I just prefer to remove noise if I'm going to be any pp first, so that I can get a 'clear' idea of what colours I am dealing with, editing and so on. With noiseware pro, you can add sharpening into the noise removal process, works well, not sure if Noise ninja has that option, as opposed to using photoshop/lightrooms built in sharpening tool.
PostPosted: Mon Aug 04, 2008 10:34 am
I have seen it for myself, that's how I reached the conclusion. I think it depends on the kind of shot you are taking. For portraits, I don't find the loss in detail to be significant but for landscapes, completely different story.
In NR, you remove detail that simply cannot be recovered later. It's the same with contrast increases. I always add contrast as one of the last steps in PP(thanks for the tip Zorro!) because it otherwise means working on the image with clipped highlights and shadows.
Graham
