It is currently Wed Jun 19, 2013 8:38 pm
PostPosted: Thu May 15, 2008 3:18 am
I have Adobe Photoshop 7 and CS2, IrfanView, RAWPhotodesk, KUSO Exif viewer, and Opanda IExif programs. How do I save the metadata of a picture so that if I need I can write it back in there again? Can you import metadata back into a picture again?
Let's say I want to edit some things in Photoshop. It normally stips out the metadata of the lens type, etc along with some other data. So when I get done I want to put it back into the image again.
Possible?
Cheers!
Vern
http://vernsdidj.com Didgeridoo info and other pictures and links.
"You will know the truth, and the truth will set you free."
(Jn 8:23)
"I started out in life with nothing....and I've managed to keep most of it!"
PostPosted: Thu May 15, 2008 8:53 am
Hi Vern,
I've never used it but I see that Opanda PowerExif boasts a "powerful import & export function". Is that the program you currently use?
I did quick search this morning which revealed ExifTool by Phil Harvey. Another one that I haven't tried but I've added it to my Bookmarks against the day when manual EXIF editing inPhotoshop CS2 isn't enough.
PostPosted: Thu May 15, 2008 11:17 am
Bob Andersson wrote:
Hi Vern,
I've never used it but I see that Opanda PowerExif boasts a "powerful import & export function". Is that the program you currently use? Bob.
I have the Opand IExif viewer. I just recently downloaded a new program called PhotoME that does export and import of exif data. Haven't done much with it yet, as I just downloaded it. Found it from a link to a link, etc and former Exifer author recommeded it. It, too,like Exifer is German built http://www.photome.de/ So far looks good. :)
Cheers!
Vern
(Jn 8:23)
