It is currently Fri May 24, 2013 10:09 pm
PostPosted: Fri May 09, 2008 10:20 am
any ideas folks why CS3 wont open raw files from my 40D..........??
it worked no problems with mt previous Olympus E500.......
i realise the canon comes with it own software but i don't like it and wish to use cs3.
thanks for any help given,
Daz
http://www.darrenturner.org & www.finepixels.org
Canon EOS 40D & Canon EF-S 17-85mm f4-5.6 IS USM Lens & Canon EF 70-300mm f4-5.6 IS USM Lens
PostPosted: Fri May 09, 2008 11:54 am
........ check to see if you need to update the raw converter within PSCS3...... it will be on the Adobe site under updates or support
PostPosted: Sat May 10, 2008 12:15 am
As Big Pix says you need to update your camera raw the version you need is Camera Raw V4.3 at least for your 40D, think they are up to V4.3.1 now for some newer cameras
Roy
My Fotopic :-)
PostPosted: Sat May 10, 2008 4:02 am
yep, every update for adebe camera raw converter adds support for the latest camera models :) i had problems with opening raw files from an eos 400d in photoshop cs2 but after an update everything seems to be allright, it's works just perfect :)
Cheers,
HNV
"Make things as simple as possible, but no simpler." Albert Einstein
PostPosted: Sat May 10, 2008 9:03 am
thanks alot folks will try that now.
Daz
