It is currently Sat May 25, 2013 12:30 am
PostPosted: Sat Mar 22, 2008 10:04 pm
Hello all,
I am having a bit of a problem that is going to make me look very stupid but to save myself more time trying to solve the problem, I decided to leave myself open to ridiclule and give the forum a good laugh and to ask the question.
Ok its probably one of the basice questions and commands on the programe but when I try to use any command other than the Pan or hand tool, the program will not let me select anything on the screen and the pan /hand icon stays engaged.
I have been playing around with photoshop for a while now and this has not happend to me before. It is also happening with me on another editing programme I sometimes use.
Hope that all made sense. Any ideas
Life through a lens but not as it seems Jim.
PostPosted: Sun Mar 23, 2008 12:31 am
mac or the other one [p.c.]
is it a genuine copy
and are the options ticked at the top of page
PostPosted: Fri Apr 11, 2008 9:27 pm
Hi Big Pix ,
Thanks for replying and I apologise for being so rude as to not answer you but it is a very busy time for me and I only get snatches of time on my pc and less time with photoshop.
I am using windows to run the programme and it is not a copy although I did borrow the programme from someone else so maybe that would effect it.
Sometimes if I change the name of the layer it will start to work properly for me and after a while i have to change the name again as the tool I want to use refuse to show on screen even though it has appear in the task bar? as being in use.
It is highly annoying as sometimes it let me go so far and then just starts to not work for me..
I have changed over to coral paint shop pro x sometimes when adobe lets me down only to find the same thing is happening there.
Any help gratfully accepted
PostPosted: Fri Apr 11, 2008 9:33 pm
....... have a look at your preference settings for the programs....... also having your caps key on affects how some tools work
PostPosted: Fri Apr 11, 2008 9:49 pm
It sounds more like a general pc issue, rather than a program specific problem. Is your computer up to the job? Are all your other programs behaving as they should?
Zorro 8)
PostPosted: Fri Apr 11, 2008 10:39 pm
...... maybe not enough memory......
PostPosted: Sun Apr 13, 2008 10:15 pm
Thanks for your help everyone. It is still happening to me but i find if I rename a layer the program works properly for another while until I have to rename again.
Think I will concentrate on getting the shot right with the camera in the first place :D
