It is currently Tue May 21, 2013 5:11 pm
PostPosted: Wed Feb 02, 2011 10:13 pm
As I'm not willing to follow every upgrade-step of Adobe I use currently LR3 for cataloging, simple processing and exporting. PS CS4 is for more demanding edits.
I use both programs like that: When I have selected one image in LR3 that need some extra processing in CS4 I use the “export to PS” command. LR3 then produces a 16 bit tiff (in my case), starts PS, and off we go. This has the benefit of using the improved RAW-conversion faculties of ACR 6.3 (in LR3) vs. ACR 5.x (in PS CS4).
BUT:
Whatever I've done so far in LR3 (like say a +1EV exposure compensation) gets cooked into the tiff and thus transferred to PS. Unfortunately there is some loss involved in the "cooking"/transferring to tiff as I discovered the hard way. So you should do no fancy processing in LR3 before transferring it to PS or else you might end up with unrecoverable damage (not to the NEF, mind you).
This in principle is also true if you have upgraded to PS CS5, but then there is no reason to use the RAW-converter of LR3 any more.
Any thoughts on that?
PostPosted: Sat Feb 05, 2011 9:04 am
What about DNG? Does that work better in this case?
- Wout -
PostPosted: Sat Feb 05, 2011 10:48 am
Nope, there's no escape from the "cooking" unfortunately.
PostPosted: Sat Feb 05, 2011 11:36 am
although i can't use raw i have encountered the same problem with lightroom, export to ps saves the development stuff done in lightroom, thats why i transfer my photos to hard drive, import to lightroom, do development, and export to new location on hard drive, than if i want something edited more i can simply take the original and edit, and save it in the export folder of lightroom, and delete/keep the other originals..
add me up on:
flickr:
deviant art:
PostPosted: Thu Feb 10, 2011 4:34 am
Thomas wrote:
BUT:
Thomas,
Perhaps I am missing something in your post but I don't understand your cautionary tale as isn't the point of exporting to TIFF is so that you can work on the file in PS, as PS doesn't operate on RAW files.
Also, I am confused by this statement, because why would one opt to not do fancy processing within the raw converter where you have more control, and then export the processed result to PS?
PostPosted: Thu Feb 10, 2011 7:05 pm
Yeah, perhaps it's a bit over-simplistic.
But my hunch is that if you plan on doing some "fancy" processing (with the help of PS) just use LR to get the exposure and dynamic range right.
Because after "cooking" you don't get headroom or shadow detail back in a way that you can from the original RAW.
PostPosted: Thu Feb 10, 2011 9:49 pm
I think that if you use the option “open as smart object in Photoshop” from LR3 there is no cooking involved. With the smart objects you can always revert back to camera raw and make adjustments. If you close the file in Photoshop you end up with a separate cooked TIFF file, your original is preserved with the adjustments made in LR.
Radu
Canon PowerShot S100
Canon580EXII
http://www.errre.net
PostPosted: Mon Feb 14, 2011 8:08 am
What you are actually getting is an upgradeable "rendered" image, the raw file is actually included with the PS file from therein and the original LR raw file will no longer be updated.
PostPosted: Mon Feb 14, 2011 11:31 pm
For me this is the strength of LR3, cataloging & simple processing and it forms the mainstay of my workstream. However, I did upgrad to CS5 and therefore dont have the same issue but work with the NEF file directly, only converting to a tiff etc when saved. I agree with you entirely the PS is for the more demanding edits and artistic touches, well thats how I use it within my sphere anyway.
Therefore, for the way I work there is a reason to use the RAW converter of LR3 :!:
Alan
D4 & D700
http://www.alanwilliamsphotography.co.uk
BLOG: http://www.ayrshireweddingphotographer.org
