It is currently Thu May 23, 2013 7:46 am
PostPosted: Fri Sep 10, 2010 11:31 am
A quick question about lightroom 3 do you to convert your RAW file into .JPG or whatever is the best conversion of RAW into something else so you can import it into Lightroom 3?
would you rather convert your RAW files into JPG or is there something else that can be used to convert it without losing any details of the image.
Edit: would you rather use the adobe products (LR3 and CS4/5) than the DSLR editing software?
PostPosted: Fri Sep 10, 2010 11:55 am
You can import RAW files into Lightroom as they are. You don't need to convert them to anything to import into Lightroom. I convert my RAW files into DNG files when I import them into Lightroom but aside from that, you can just import the RAW files as they are.
PostPosted: Fri Sep 10, 2010 12:15 pm
how about after tweaking the RAW file what file extension would you use? also planning to print some pictures that i'm going to tweak later today.
so what is the best image file for printing without any losing details of the picture.
1) .TIFF (but its big)
2) ?
3) ?
PostPosted: Fri Sep 10, 2010 5:50 pm
TIFF is the best as it's lossless.
Check out: http://www.eagle1337.deviantart.com/
Camera: Canon Rebel T1i
Lens: Tokina 11-16mm f/2.8, Sigma 17-70mm OS DC HSM f/2.8-4, ef-s 18-55mm IS, ef-s 55-250mm IS. EF 50mm F/1.8
Tripod: Giottos MTL9351B with a MH 5001 head.
Bag: lowepro Slingshot 202 AW. Cards: Sandisk Ultra 2, Lexar MicroSDHC.
