It is currently Fri May 24, 2013 1:29 pm
 Post subject: FixerLabs FixerBundle V2
PostPosted: Mon May 17, 2010 10:58 pm
FixerBundle consists of 4 plugins:
1, FocusFixer
2, NoiseFixer
3, ShadowFixer
4, TrueBlur
FocusFixer is what drew me to the site. This claims to be able to recover out of focus areas. In a quick play with slightly OOF areas, I haven't managed to achieve this. Possibly because my photos tend to be taken at high ISO, it does so some kind of sharpening or local contrast adjustment, but it also amplifies noise. I'll play with it some more, but it seems too good to be true at the moment.
NoiseFixer is yet another noise reduction tool. I tried a quick play with settings of 100% colour noise reduction and 10% luminance noise reduction. On one test sample it seems to perform on a par with Neat image.
ShadowFixer is as you can guess a shadow recovery tool. Comparing it directly with the Shadow tool in Photoshop Elements 7, they do work differently. PSE7 seems to maintain more colour in the shadow than ShadowFixer, which has an extra radius option not in PSE7. I haven't figured out how best to use that yet as turning it up just seems to introduce harsh contrast in detail and haloing on bigger changes.
TrueBlur I haven't touched yet. It appears to be a combined blurring and noise adding tool.
I've yet to play about with it some more, but so far it doesn't look like it provides much beyond what I already have.
PostPosted: Tue May 18, 2010 4:11 am
I have serious doubts about fixing focus in post unless you know which points of light map to which location on the imager.
You'd need something like this:
http://www.youtube.com/watch?v=9H7yx31yslM
PostPosted: Tue May 18, 2010 12:31 pm
It could also be doing something similar to the refocus plugin, that's available for Gimp. http://refocus.sourceforge.net/
In short, I doubt it's going to work as well as advertised.
PhilipGoh.com
PostPosted: Tue May 18, 2010 4:31 pm
Ooh, will have to look into that later.
There's the old saying, if it sounds too good to be true, it probably is. Still, worth a try in case it is true!
