It is currently Tue May 21, 2013 9:40 am
PostPosted: Fri May 15, 2009 12:26 pm
Im trying to make a online album, which i have done, but I get the message of:-
'SimpleViewer requires Adobe Flash. Get Adobe Flash. If you have Flash installed, click to view gallery.'
I click on the bit that says 'click to view gallery' and i can then see it.
but i want it to just open the gallary striaght away.
I know a little HTML so i can edit the code if i need to.
this is the code for that bit above
<div id="flashcontent">SimpleViewer requires Adobe Flash. <a href="http://www.macromedia.com/go/getflashplayer/">Get Adobe Flash.</a> If you have Flash installed, <a href="index.html?detectflash=false">click to view gallery</a>.</div>
Please help.
thanks, Neil
Amateur, always learning!
PostPosted: Fri May 15, 2009 2:57 pm
hmmm seems to have stopped it now, but does anyone else get it on my site..
http://www.phil-knight.co.uk/NeilDavison/
PostPosted: Fri May 15, 2009 5:25 pm
append ?detectflash=false to your index file. You'll need a way to automatically do this, maybe by a redirect from index.html to the appended version. It's a cheap workaround though, I'm sure there are better coders here with a more elegant solution.
