It is currently Wed May 22, 2013 4:15 am
 Post subject: wat is the head ??
PostPosted: Fri Apr 18, 2008 12:04 pm
wat's The difference between the ball head and the three way .. ??
PostPosted: Fri Apr 18, 2008 12:15 pm
Hey,
Have a look at this Wikipedia article about tripods, specifically the heads:
http://en.wikipedia.org/wiki/Tripod_(photography)#Heads
EDIT: copy and paste the whole link into the browser address bar. There seems to be a problem with the brackets in the link - but they should be there so you'll have to copy it in. 8)
PostPosted: Fri Apr 18, 2008 1:05 pm
thnx for the link it helped .. but i still dunno wat i i need a ball head or not .. i have the panasonic fz8 .. and this is my first time to buy atripod and dunno wat the best for me .. and the ball head can be attached to anytripod ?
PostPosted: Fri Apr 18, 2008 1:09 pm
What kind of shots do you want to take with the tripod? And you'll probably need to get one thats compatible with the tripod you buy (or just buy it with the tripod from the start).
PostPosted: Fri Apr 18, 2008 1:16 pm
doing Some HDr Shots .. Macro .. Night shots .. so wat to u think ?
PostPosted: Fri Apr 18, 2008 2:00 pm
Ball heads are the quickest to set up but they sacrifice stability and accuracy of positioning.
Graham
PostPosted: Fri Apr 18, 2008 2:05 pm
Yep Graham's right - a ball head will allow you to set up quickly however, you may find that the 3 way gives you more stability, which you'll need if you're doing a lot of macro/night shots. You'll need to make fine adjustments to make it accurate but the 3 way head should allow for greater stability. And you'll still be able to pan effectively (although this is often easier hand-held anyway).
PostPosted: Fri Apr 18, 2008 11:35 pm
thnx guys for the advice ..
PostPosted: Thu Apr 24, 2008 4:14 am
Do you leave the shutter open longer for macro shots?
PostPosted: Thu Apr 24, 2008 8:19 am
You can if you want to, just make sure the subject doesn't move.
Graham
