It is currently Mon Jan 23, 2017 10:34 am
 Post subject: Gimbal for my tripod
PostPosted: Tue Oct 18, 2011 7:00 pm
I`ve been told for wildlife photography a gimbal is the way to go on my tripod, some of the prices are incredible! obviously i don`t want to put my 1000d and sigma 500 lens on something that won`t take the weight so i`d like some advice from anyone who has some experience of this, Many Thanks
PostPosted: Tue Oct 18, 2011 7:09 pm
I was recommended the Manfrotto 393 Long Lens Monopod head previously. It is rather affordable compared to most. I did get one, but I never used it as the 300/2.8 lens I bought it for I didn't keep around long enough...
On that note, basically if you can get away with holding the lens by hand, do it. Only if you have a bigger lens that's too heavy to carry does this start to make sense.
PostPosted: Fri Oct 21, 2011 3:49 am
The most respected gimbal head for wildlife is the Wimberly. I tried it recently and loved it for stills, but it wasn't so good for video. For video, I preferred the Manfrotto 393 bracket, but it is much bigger and heavier...
In both cases I was using an EOS 7D and EF 500mm f4L lens.
PostPosted: Mon Oct 24, 2011 8:39 pm
If you're a serious wildlife shooter & can afford a Wimberley, they are reckoned to be the best. They also make a `sidekick` which is about half the price.
A cheaper option again is the Manfrotto 393. It's bulkier (though not much heavier) but seems well made & easy to use even on a monopod.
My mate borrowed mine a couple of days ago & liked it.
. Image
PostPosted: Fri Oct 28, 2011 7:47 am
Hmmm, I used the 393 with the lens hanging down!
PostPosted: Fri Oct 28, 2011 9:15 am
Hi Gordon. I find it easier to use in the `cradle` position. It feels more natural, less top heavy & more stable somehow.
It also negates having to rotate the lens foot & collar.
I guess using it `on the top` would give extra height on a shorter monopod/tripod though.
PostPosted: Fri Oct 28, 2011 11:21 am
It varies with the lens and tripod mount it comes with, and therefore where you put the centre of gravity in the configuration.
PostPosted: Fri Oct 28, 2011 1:24 pm
It comes with the long 357PLV sliding plate.
It locks into the `gimbal` by tightening a levered screw on the side & extra security is by means of a spring loaded pin to stop your lens sliding out, but because you can slide it forward or backward before locking it off, you can balance it for centre of gravity.
http://www.nikonians.org/html/resources ... 393_1.html
 Post subject: Re: Gimbal for my tripod
PostPosted: Sun Sep 21, 2014 12:25 pm
Just a quick update.
I still use the 393 head, but my mate (in the photo above) bought one of these `Lensmaster` last year & uses it with his D4, 400mm F2.8 + 2X TC. He really rates it; http://www.lensmaster.co.uk/buy-rh2.htm
