Hello all,
I am currently looking at two of the Giottos VGRN Vitruvian models (
http://www.giottos-tripods.co.uk/index. ... ae6ded2454). The VGRN9265+5501-652 and VGRN9255+5400-652.
For ease of reference I am posting some stats here:
VGRN9255+5400-652SRP £200 inc vat
Material
Aluminium
Folded Height 40cm
Minimum Height 27cm
Maximum Height without Centre Column 142cm
Maximum Height with Centre Column 165cm
Weight 1.55kg
Maximum Weight Capacity 6kg
Number of Leg Sections 5
VGRN9265+5501-652SRP £260 inc vat
Material Aluminium
Folded Height 40.3cm
Minimum Height 28.6cm
Maximum Height without Centre Column 147cm
Maximum Height with Centre Column 171cm
Weight 2.03kg
Maximum Weight Capacity 9kg
Since I am only going to hold a d7000 along with a mid sized lens, weight capacity on both is fine. In most aspects they are identical. I am not opting for carbon fibre because the price difference is huge but weight isn't (about 0.3kg).
On the heads, the VGRN9265+5501-652 has a friction control dial where as the VGRN9255+5400-652 doesn't, but the weight difference is 1.5kg to 2kg.
This will be my first tripod and will be used for landscapes mostly.
My question...is a friction control dial worth 0.5kg?
Also both are priced at £170. I am open to other suggestions but for weight, size when collapsed these seem the best option.
Thanks
Dave.
