It is currently Sat May 18, 2013 5:10 pm
 Post subject: Tripod Help need :(
PostPosted: Thu Nov 24, 2011 1:08 pm
Hi All
I am planning to buy Manfrotto 55XPROB with 808Rc4 or 804 RC2 heads..
Is it a good combination for wildlife , sports and esp bird photography???
Please suggest me so that i can go ahead on the same.
PS: I have never used tripods so far and the reason going for 808 and 804 heads are because of their handles(assuming that it will be easy to handle)..
Regds
Mano
Canon EOS 5D mk III|Canon EOS 7D | 70-200 F2.8 L IS II USM | 400 F5.6 L USM
PostPosted: Thu Nov 24, 2011 1:31 pm
I think you'll want a ballhead or a wimberly head (or the manfrotto cheap alternative) for sports and bird photography.
PostPosted: Thu Nov 24, 2011 7:02 pm
Agreed - ballhead is the way to go.
Trevor Harris
Nikon D200
SB-600
YN-560 II
YN RF 603 x 4
Tamron 17-50mm f/2.8
Nikon 50mm f/1.8
PostPosted: Thu Nov 24, 2011 7:11 pm
Make sure the tripod & ballhead are rated for the correct weight of your equipment, (camera, lens, gimbal etc ) maybe even better to get a higher rated set up 1st, than find out later you could do with a more solid set up.
`Gimbal` thread; http://www.cameralabs.com/forum/viewtopic.php?t=28468
PostPosted: Sat Nov 26, 2011 7:56 am
I'd go for a ball head or a wimberly gymbal, but I'd also consider going for the 055CXPRO carbon fiber model, asnthe aluminium 055 versions are very heavy.
