It is currently Thu May 23, 2013 5:09 pm
 Post subject: Help/advice please.
PostPosted: Wed Nov 17, 2010 8:51 pm
Couple of questions.
1; Just wondered if anyone has experience with Giotto tripods? I can't afford anything better, but don't want to waste money if they're not up to the job.
The aluminium MTL9361B seems to fit my needs.
2; Also having never used a ball-head, (I don't know whether they're strong enough to attach & hold a field-scope or camera & larger zoom lenses without slipping/tilting) Are they as strong/hard wearing as a 3-way?
Would the (15kg) MH1300-652 be fine, or is it better to stick with a 3-Way Head, like the MH5001 ?
Thanks in advance.
PostPosted: Fri Nov 19, 2010 6:49 pm
1. I have a giottos tripod, it works fine.
2. I have the mh5001 and some piece of metal came out of it, other then that it seems fine.
Check out: http://www.eagle1337.deviantart.com/
Camera: Canon Rebel T1i
Lens: Tokina 11-16mm f/2.8, Sigma 17-70mm OS DC HSM f/2.8-4, ef-s 18-55mm IS, ef-s 55-250mm IS. EF 50mm F/1.8
Tripod: Giottos MTL9351B with a MH 5001 head.
Bag: lowepro Slingshot 202 AW. Cards: Sandisk Ultra 2, Lexar MicroSDHC.
PostPosted: Fri Nov 19, 2010 7:48 pm
Thanks Eagle.
Can anyone answer whether the ball-head should be stable with heavier kit, as long as it's within the weight bearing capacity?
PostPosted: Fri Nov 19, 2010 8:48 pm
a ball head should be fine as long as you don't exceed it's weight limit. I prefer a ball head to a 3-way head.
