It is currently Thu Jan 19, 2017 12:45 am
PostPosted: Wed Dec 18, 2013 1:16 pm
Pinhole_small by cybermystic, on Flickr
Made a new pinhole camera for this winter Solstice based on a 4-inch plastic drain pipe and 8x10-inch photopaper. Pinhole made in a piece of Aluminium foil stuck over a 1-inch diameter hole drilled through the side of the tube. Aluminium foil around the tube to make it light tight and waterproof end caps on the end of the pipe to keep both light and the water out (hopefully). Will put it out on Friday evening and then I have a 6-month wait to see whether it worked or not. Check back on June 22nd 2014 for the answer.
Greg
