It is currently Fri May 24, 2013 10:56 am
PostPosted: Mon Aug 20, 2012 7:37 pm
Today's sun... all images are 100% crops from DMK41. Best 10% of 1000+ frames.
Thought I'd have a go at the prominences close up. Far from easy... since I don't have any workable barlows at the moment, I decided to use eyepiece projection with a Hyperion to T-mount to DSLR to C-mount... this was my first capture of the prominences around 4 o'clock of the disc. I blew the surface here...
Here I moved over to the prominences around 8 o'clock of the disc. I fiddled a bit more with the video settings and managed to get both prominences and surface detail at the same time.
Side note: I find when I stick more glass in the chain, I can get a diagonal stripe appearing near the centre of the image. It seems to be due to the optical chain, but I'm at a loss as to what causes it, or what could be done to eliminate it.
Now I'm wondering if I can get better detail out of a regular PST (single stack), or would there be better gains from going DS or a stage 1 mod to bigger aperture scope...
PostPosted: Mon Aug 20, 2012 7:56 pm
great work popo. What you are experiencing is the tilt filter inside the PST. in order to get modify the view with more surface details or more prominence, they tilt the filter to change the angstrom value which in return create an uneven illumination. You won't notice when you do visual but when you capture with an DMK, you will notice.
This is why Lunt came up with the Pressure Tuner. Instead of tilting they use air pressure to move the filter so the illumination is even on all side.
PostPosted: Mon Aug 20, 2012 8:56 pm
I'm not sure that's it, at least not in itself. The diagonal pattern, I would have to describe as like interference fringes. You can see a small patch of it in the 3rd pic just to the left of the filament bottom centre. It is in the same place and doesn't seem to change with etalon adjustment or focus. It probably is some interference effect, but where? It only appears when I try using higher magnifications.
PostPosted: Mon Aug 20, 2012 9:31 pm
Condensation or dust in the optical train maybe ? Like condensation mark on a barlow ?
PostPosted: Mon Aug 20, 2012 9:51 pm
It's too regular to be those I think. I've not seen condensation on a barlow, but I've seen the stripe effect both with a barlow, and with eyepiece projection as I used in this case. I guess saying that, it suggests it's something to do with the PST and there's not a lot in there...
