It is currently Fri May 24, 2013 11:14 pm
PostPosted: Sun Oct 02, 2011 9:37 pm
Managed to tune in the mini-WASP array with this run of clear Moonless skies and managed to let the beast loose on the North America nebula for a couple of hours. Very pleased at how this one turned out.
Greg
PostPosted: Sun Oct 02, 2011 9:59 pm
That is fantastic! If I wore a hat, I definitely take it off to you!
PostPosted: Sun Oct 02, 2011 10:20 pm
Awesome!
PostPosted: Sun Oct 02, 2011 11:05 pm
Nice as always, but if I can ask, how "deep" did you go? I'm still experimenting with my early tries in narrowband imaging, but with all its many faults I got more red stuff with 4 minute subs at f/2. A dedicated sensor has never been so tempting...
PostPosted: Wed Oct 05, 2011 12:24 am
Hi Greg,
Today marks the first opportunity I've had to see this on a big screen. Nice work! Can you spare a few moments to tell us how the image was captured or point to a web page where you've already done so? Did you use any filters, how many subs, as it is a mosaic and how many frames? What's the pixel count for the full-size image? The usual questions... :)
PostPosted: Wed Oct 05, 2011 11:55 am
Hi Bob,
This is a 3-framer using the Sky 90 and the M26C one-shot colour camera. The filter is just an IDAS light pollution filter to try and cut out all the street lights. Each frame is just one hour (I was amazed and it shows how good the M26C is with a short focal length refractor) consisting of 6 x 10-minute (dithered) subs. The pixel count in the original is 3377 x 4341 with quite a bit of cropping out of stuff on the right hand side and at the bottom as I just wanted the North America nebula as the subject.
Greg
PostPosted: Wed Oct 05, 2011 1:37 pm
Thanks Greg. At my current rate of progress it will be next year before I can tackle that area of the sky with the new kit but the numbers will be a useful crib to get me started!
Interesting to see how much Hα I lost with my 5D Mark II effort a while back, though my total exposure was only about half yours which wouldn't have helped my cause!
PostPosted: Wed Oct 05, 2011 2:59 pm
That also gives me a useful guide on what to aim for. Roughly speaking, assuming no reducers were used with the Sky 90, that's a f/5.6 optics. When I tried H-alpha imaging those 4 minute exposures at f/2 would have been equivalent to 32 minutes at f/5.6. So putting aside sensor sensitivities I did go a bit deeper. I think I can afford to back off, both stopping down and maybe using shorter exposures to control the negative aspects of my setup.
I think I'll have to re-read Greg's book again as it has been a while since the last time I looked at it. I vaguely remember the question of exposure duration, aperture and "deepness" raised but can't recall the conclusion.
Bob, I hope you do have a chance this year to have a go around Cygnus. Seems to be so much there to explore. But if you do end up missing it, there's always Orion to look forward to :)
PostPosted: Wed Oct 05, 2011 5:16 pm
There is always an f#4.5 reducer/corrector on the Sky 90 - you can't take reasonable CCD images without it.
Greg
