It is currently Thu Jun 20, 2013 10:05 am
PostPosted: Mon Aug 08, 2011 2:55 pm
Wel here's the evening I thought would never come - first light for the mini-WASP at the New Forest Observatory. I started to Polar Align and then gave up and went straight onto a bit of imaging - the stars were too nice. One camera worked fine, the other camera seemed to have a problem with the cooling circuitry and is now on its way back to SX. Never mind, one imaging camera and one guide camera are all I need. The guiding was to within half a pixel all night using the parameters straight out of the box - says something about the Paramount!! This first light test shot has had no processing apart from a little brightening up so you can see all the hot pixels, the Polar rotation and the dust bunnies - but it is a 2,000 second sub using the M26C camera and so it shows the potential of the array when both M26Cs are running (and ultimately when all 4 are running!!!). Long time coming - over 4 years since I first talked about this - but finally got there :D
Greg
PostPosted: Mon Aug 08, 2011 4:21 pm
2000 seconds! That's... over half an hour "out of the box"? :eek: Hate to think of the output you'd get with a little fine tuning and additional sensors...
PostPosted: Wed Aug 10, 2011 9:22 am
Hopefully I'll be able to show you by the end of the month if I get enough clear skies to be able to properly polar align the mini-WASP array.
Greg
