It is currently Tue Jan 17, 2017 3:04 am
 Post subject: M42 Expanded
PostPosted: Sun Mar 06, 2011 2:35 pm
Well, on Friday night I manages to get out again and do some more imaging.
I decided, due to the long focal length of my scope, to try getting the running man (NGC 1977) to add to my M42.
I had great difficulty in adding the mosaic together. First I chucked it all into DSS, which seemed to do the job but the results were not that good. There was a distinct dark band where the frames overlapped and the stars to the bottom of M42 went a bit funny.
So I decided to stack M42 and tweak in DSS. Then stack the Running Man and tweak in DSS using the same settings as for M42.
In photoshop I then combined the two and masked out the dark band.
M42 - 6 x 600s Subs, 4 x 600s Darks, Bias, no flats
Running Man - 6 x 600s Subs, 8 x 600s Darks, Bias, no flats
Guided with Atik Titan and finderguider
Stacked in DSS
Finished in CS4
Im not entirely happy with the core of M42, it seems a bit grubby, if you know what I mean. I think I need some better subs for the core. Still its one to work on.
As always comments and critique welcome.
Lee Diggle
PostPosted: Sun Mar 06, 2011 5:19 pm
Nice running man. Is it me or does M42 in general look less vibrant than your previous post? I think you can "turn it up" a bit in processing there. Edit: had a quick poke at this in photoshop, I think it helps a lot if you just shift the black point in levels a bit.
Can't wait to see you having a go around the horsehead.
PostPosted: Sun Mar 06, 2011 6:05 pm
Hi Popo,
I think you are right.
Hows about this:
Im looking forward to trying the Horse Head and Flame too....
Lee Diggle
PostPosted: Sun Mar 06, 2011 7:53 pm
Fantastic, especially the second version. :)
