It is currently Sat May 25, 2013 6:00 am
PostPosted: Thu Dec 17, 2009 4:14 am
Thought you all might be interested in seeing some micrographs taken using a scanning electron microscope. I had the pleasure to "play" with one for a few weeks several years ago. Saw a lot of crazy things and got some neat shots. Dug these up last week when I ported all my stuff to a new computer, and decided to share. Enjoy!
Ragweed Pollen
Centric Diatom
Dinoflagellate
Duck Feather
Butterfly Wing Scale
Cottonwood Leaf Xylem
Chain-Forming Diatom
Bacterial Colony around the Hair of a Midge Fly Larvae
Lilly Pollen
Hair Filaments on Female Copepod
Diatom
Tapeworm Eggs
Comments welcome...
Nikon D300 / 35mm f1.8 / 300mm f4 / TC-14E II
Pentax K200D / DA 18-55mm / DA 55-300mm
PostPosted: Thu Dec 17, 2009 1:31 pm
Oh wow. That last one is quite awesome, it looks like some futuristic building!
--Zoeff
Panasonic GH2 user
My photos can be found on flickr.
PostPosted: Thu Dec 17, 2009 5:42 pm
I really like those diatoms.
The scale interests me too. I wonder if I can photograph them with my macro setup, as I can get better theoretical resolution than 1 pixel = 1 um (diffraction allowing!). It would still be significantly less than those of course.
PostPosted: Thu Dec 17, 2009 10:29 pm
Thanks, Zoeff. The last one is one of my favorites, too. Believe it or not, the image is techincally "overexposed." If we had the capacity to view diatoms, we wouldn't be able to see the honeycomb structure beneath the sheath. It's a little wild to think about the different forms and how they're constructed. Little living organisms with that honeycombing, overlayed with a band of tissue round the center. Very strange.
popo, not sure about macro photography. Greg's fractal-sharpened butterfly wing is the closest I've ever seen someone get to the individual scales using something other than a microscope. I don't know how your setup differs from his, nor am I knowledgeable enough to comment on the actual resolving power of a macro DSLR lens + TC.
Just as an example, though, most snowflakes are somewhere between 7000 and 10000 um in diameter, whereas butterfly wing scales are on the order of 100 um or less. I'm curious about it, though, so it would be great for you to give it a shot!
PostPosted: Thu Dec 17, 2009 11:04 pm
I think I had a poor choice of words back there. I was referring to general image scaling, not the butterfly scale. I fancy a go at diatoms if only I knew how to get some.
Having said that, I had a play with a moth in the past. I could *in theory* more than double the optical magnification from that, but shallow DoF and diffraction are highly limiting, and I'm almost certainly pushing the lens way beyond its design limits.
PostPosted: Thu Dec 17, 2009 11:10 pm
Ahhh! I understand now. :wink:
Diatoms can be found in several places: plankton tows and soil samples (which would be really hard to sift through if you're looking to separate the little buggers from the rest of the mush) and on the surface of fallen, decaying leaves. That might be your best shot. If you've ever seen a leaf where the surface tissue has been eaten away, leaving on the veins, it's the work of diatoms. If you can pick up some fallen/decaying leaves from riparian areas, you might get lucky.
PostPosted: Thu Dec 17, 2009 11:24 pm
I have seen the leaves you describe, but didn't know how that happens! Might be a bit late in season for that now.
I did do a search and found a place that sells prepared slides so I think that's a lot easier for me to find :D
PostPosted: Tue Dec 22, 2009 12:57 am
Updated 12/21/09: Additional micrographs added.
