It is currently Sun Jan 22, 2017 10:31 pm
PostPosted: Fri Oct 23, 2009 8:35 am
If you are an astrophotographer have you ever thought of turning your hand to spectroscopy?
After following a link on a British Astronomical Association circular this morning I came across the STAR ANALYSER.
I have no experience with this product and I imagine that many other similar products exist out there on the Net if you look so this post is in no way intended as a personal endorsement. Spectroscopic gratings have been around forever but the pleasant surprise was how cheap they have become. The example above is comfortably below £100 ($167). Pair such a filter up with a 200mm f9 reflector and a Philips ToUcam Pro webcam and you can capture a spectrum of Vega, one of the brighter stars in the sky, thus:
and apply some post-processing to achieve this:
These and other images are available for your perusal at the PATON HAWKSLEY EDUCATION LTD website.
PostPosted: Fri Oct 23, 2009 8:42 am
Interesting, although I'd be interested in using one the other way - using it to measure the response of the camera sensor.
I have seen cheap diffraction grating films before e.g. here although for this DIY approach you'll need to work out the angle of deflection for a given line spacing to determine a suitable one allowing for sensor size and distance.
