It is currently Wed May 22, 2013 3:29 pm
PostPosted: Thu Aug 20, 2009 11:47 pm
Best yet - I can see the cloud bands now :)
2650mm f/26 1/10s ISO400
7 shots manually selected from the evening's takings, cooked by registax, garnish with a light application of photoshop.
I really need to get that webcam...
PostPosted: Fri Aug 21, 2009 9:24 pm
That is a very good attempt. You got more then I could ever get out of my DSLR for planets.
PostPosted: Fri Aug 21, 2009 9:51 pm
Seeing was variable at the time. For an average of maybe 1 second in 10 it would stabilise enough and I could see two red bands in the middle by eye. With the camera on, it looked similar, and I just tried to time the shutter presses to when it was good. Snag is live view goes out of magnified view after each shot, so either I had to re-zoom (and wait for vibrations to stabilise again) or just try to tell from the small image and hope for the best. I did a mix of both. Took 60 shots in total, including some longer ones to bring out the moons but blowing out the planet in process.
Anyway, I have the cheap meade imager on order now :)
Tonight I just played about a bit with the 5 inch newtonian. I never used it much for two reasons: In initial testing the prime focus is too far in to use with a camera, and secondly I'm too lazy to figure out and set up the equatorial mount. I never got round to seriously using the computer control on the other scope either! This time I blindly set up how I think it works, guessing where north is and playing with the motor. I wasn't that far out for guessing, with only a slow drift on up/down plane and with some patience I could set the right speed to sort out the left/right drift. Now I need to find the manual again and see what I should have done.
Even if I can't use it with a camera, I can do piggyback with it... but there doesn't seem to be any really bright objects in view at the moment.
PostPosted: Mon Aug 24, 2009 3:45 pm
M31 is high enough now. 30 sec exposure should be enough to bring out some details without trailing. You can also try M13 in the Hercules constellation. 2 of my favorite target.
Setting up an EQ mount is not that difficult. If you have a polar scope in your mount is makes it even easier. I use a green laser through the mount polar scope to align myself on Polaris. What I have learn, even with the best EQ mount, it's almost impossible not to introduce drifting after 3-5 min. One of the best purchase I did was an Orion StarShoot Autoguider and a Orion ST80 refractor has a guiding scope. 10+ minutes exposure are now possible to really catch faint fuzzy details.
Even with all the equipment, I failed miserably on Jupiter. DSLR and planets are a difficult combo. a cheap modify webcam will yield better result.
PostPosted: Mon Aug 24, 2009 4:27 pm
Weather allowing I might have to try those.
The biggest problem I have with setting up an eq mount is that I live mid terrace. I can only look south, or I can only look north. Not both at once. As most of the interesting stuff is south, I don't have a north reference beyond using a compass.
I have posted this before, but this was an earlier attempt at Saturn.
I have to wonder though, how much quality is possible given the diffraction limit of my scope (4 inch).
PostPosted: Mon Aug 24, 2009 5:52 pm
If you go out of the city, 4inch is more then sufficient for planetary viewing. LP is your worst enemy. Yes, you are right, South has the more interesting stuff. I have the same trouble, I can only see north from my balcony. I found several location (thanks to google map) that I can setup my gear too. You will be amaze of how much difference it makes from a Orange to a Blue/Green Zone. Black zone are obviously the best.
I went to a blue zone 2 weeks ago and now I am spoiled. It hard to go back to orange/yellow zone.
PostPosted: Mon Aug 24, 2009 6:27 pm
LP doesn't really affect planetary, unless the built up area itself makes seeing worse. As I'm very much impulsive, I've not got round to driving out for a spot yet. Trouble around here is you're never far from a built up area, and all public spaces are closed off at night.
PostPosted: Fri Aug 28, 2009 10:20 pm
My first attempt with the imager.
2650mm f/26 1/4 second individual frames
Stack of up to 153 images I put through registax shown 100% crop. But of tidying up in photoshop.
I really need to get tracking sorted out some time as I manually tracked by remote. A USB extension cable would help too.
The controls of the imager weren't very friendly with a slow screen update so I doubt the focus is exact.
