It is currently Tue Jan 24, 2017 10:01 am
Post new topic Reply to topic  [ 25 posts ]  Go to page Previous  1, 2
PostPosted: Mon Feb 09, 2009 7:44 am
I very much doubt I'll get a dedicated CCD. Quite simply my location isn't good, nor is the weather. So I don't think I'll ever make enough use of one.
PostPosted: Mon Feb 09, 2009 4:56 pm
Ian King is your guy in UK for CCD gear.
http://www.iankingimaging.com/show_category.php?id=45
Ive seen one lunar image taken through a 3" APO and CCD and the Moons disc was about 2 feet in diameter with razor blade sharp detail.
I think it was a mosaic.
PostPosted: Mon Feb 09, 2009 4:59 pm
These seem a reasonable price.
http://www.iankingimaging.com/show_prod ... tegory=100
MAKE SURE YOU CLICK ON THE "SAMPLE IMAGES" LINK!
PostPosted: Fri Jun 05, 2009 12:09 am
popo wrote:
Yesterday I got my 2nd scope. This time a Celestron Astromaster 130 EQ MD. It's a lot cheaper than the first one, but an inch wider.
That's actually the exact same telescope I'm thinking of buying (as my first telescope) that I also plan to use in conjunction with my digital camera. :)
My first choice was a Schmidt-Cassegrain type telescope such as your NexStar, however they seem to be a lot more costly compared to a newtonian one. Is there a difference in quality, particularly in the the resolving power of the two? The Celestron website claims that the resolving power is greater for the Astromaster, which isn't that surprising since it's got a greater aperture but why is it that much cheaper then?
First post!
PostPosted: Fri Jun 05, 2009 7:20 am
The nexstar series have goto mounts which the astromaster doesn't. Also the Cassegrain types are more expensive I guess the glass parts are harder to make. The newtonians are essentially a long tube with two mirrors in it.
I never used the astromaster much as I couldn't get it to work prime focus with a camera on it. The focal point is too close in. Mine does need a colimation but I don't know if that will shift the point at all. I have got a digiscoping adapter for a compact, and that seems to work ok on it as it is.
Even if I got those resolved, I'll probably end up using the nexstar more often, as it is so much smaller (length) and easier to handle from that, plus it is goto so making it easier.
But, it also depends on what you want to shoot. The Cassegrain types are inherently longer focal length small relative aperture (high f number).
If I were to buy now, I'd probably go for a bigger model in the Nexstar series. Maybe once the skies get darker again.
PostPosted: Fri Jun 05, 2009 11:58 am
I'm thinking of shooting galaxies and nebulae most of all, for that you need a low f-number, correct? x_X
Problem is that the Nexstar series appears to be about 3 times more expensive than an equivalent Astromaster series. :(
EDIT: Reading trough this forum a bit more, 5inches seem to be just too small for deep space objects unless I can properly track it and use long exposures I guess.
PostPosted: Fri Jun 05, 2009 12:55 pm
That's beyond my practical experience, but for this stuff it never hurts to have as much aperture as you can.
The Astromaster series seems intended as low cost entry level. The Nexstar series all have a goto mount which can be useful if you want it. Mounts can be very expensive too...
PostPosted: Fri Jun 05, 2009 1:39 pm
Another question, using a different eyepiece to get a greater zoom essentially means that you are using less square inch of the primary mirror, right?
PostPosted: Fri Jun 05, 2009 2:02 pm
I'm quite sure you're still using all the mirror, although at this moment I couldn't give a technical reason why...
PostPosted: Fri Jun 05, 2009 3:58 pm
Ah bummer. Thanks anyway. :)
