It is currently Tue May 21, 2013 10:08 am
 Post subject: my first time :)
PostPosted: Wed Apr 02, 2008 10:27 pm
this is my first time doin' something like this :) it's a 4 pictures collage.. a burst with a Canon EOS 400d of a friend of mine...
post-processing:
duplicate layer, desaturate (channel mixer) -> multiply
image adjustments -> shadow/highlights
merge down
duplicate layer, high pass filter -> soft light
flatten image..
so, whitout further ado, the shot.. the shots:
as usual, any kind of critique is highly recommended and welcome!
Thanks, HNV
"Make things as simple as possible, but no simpler." Albert Einstein
PostPosted: Thu Apr 03, 2008 12:24 am
Hmm it seems like you need a faster FPS because you cant really tell which direction and like what exactly is going on because the frames are so far apart.. what camera do you have??
Nikon D80/MB-D80/ ML-L3
AF-S 18-55 f/3.5-5.6, AF 50mm f/1.8D
SB-600
Vivtar 2800
My flickr
~Dan Nelson~
PostPosted: Thu Apr 03, 2008 12:35 am
forgot to mention :)) the order is from right to left :)) it's a Canon EOS 400D => 3fps burst
PostPosted: Thu Apr 03, 2008 2:00 am
Clearly emp93 never did watch his Bruce Lee...hrmpfff!!
...just kidding emp :-)
HNV, those are some good shots and a very agile friend you have there. I'd have to agree that it took even a martial arts afficionado like myself a few moments to catch on to the order. If going from left-to-right, the third one would be defying the bio-mechanics going into the kick..lol.
Not your fault that everyone automatically looks at things left-to-right. But with more frames, it would more obvious.
Regardless, the collage is a good idea. With strong side-light and that spectator in the background gone - perhaps grunged up and in B&W with some film-grain, and you could have a very strong collage!
Cheers :-)
PostPosted: Thu Apr 03, 2008 2:39 am
I like it.
Esp the background with the graffiti and the guy in the pink :)
Setup: Nikon D300 | Nikkor 18-200mm VR | Nikkor 50mm 1.8
PostPosted: Thu Apr 03, 2008 9:48 am
Its obvious that its from right to left, on the other hand that is quite the unsualy way for our eyes to interpreate things, i would suggest taking all the images inverting them and start from left to right that just the way our eyes read things!
funny stuff, you got urself some crisp shots right there!
My Picasa
PostPosted: Thu Apr 03, 2008 10:02 am
I like it - it's a nice sequence and I'm not sure having more frames per second would have helped as the gap between each pic is good in my view.
BUT for those with higher fps (all you 40D owners!) you'd effectively get a spare shot inbetween each of those above, allowing you to choose the best ones if you still only wanted , say, three or four in total.
PostPosted: Thu Apr 03, 2008 10:25 am
I like it although I think it could be improved if the subject's entire body was visible in #3. The order seems a bit odd but it's still pretty impressive!
Graham
PostPosted: Thu Apr 03, 2008 11:33 am
i did the cropping by the background :) to the exactly the same frame :)
I like it. You can see how fast it's going by comparing the movement to "background guy" :) Maybe I would have done a little longer shutter time to accentuate the movement, but that's an artistic choice I guess...
Nice work!
Velbon Sherpa 200R
