It is currently Sun May 26, 2013 3:24 am
 Post subject: More MX
PostPosted: Mon May 24, 2010 12:45 am
With the touch of a button, I can speak a thousand words.
PostPosted: Tue Jul 27, 2010 6:56 am
Looks good. If I were you I'd try and keep it tight (like you have a few shots down), thats a big trick to sports photography. Also I'm not sure if it was possible where you we're riding but I would try to get on an equal level with the bikes. It will help produce a more interesting photo that isn't a normal perspective.
Have you tried panning shots? Gordon has a tutorial here if you need it:
http://www.dslrtips.com/workshops/How_t ... hoto.shtml
One more thing, I would try to either shoot telephoto or wide angle. With extreme sports this helps give the image a bit more extremeness to it. (You did a good job of this in most of you images) just remember to avoid the 24-135mm range.
Manfrotto 055CX3 + 496RC2
www.thomaslowe.com
