It is currently Fri Jan 20, 2017 10:27 am
Post new topic Reply to topic  [ 43 posts ]  Go to page Previous  1, 2, 3
PostPosted: Wed Dec 22, 2010 7:11 pm
Good info there Gordon
For me having a limited budget when I decided to get into some airshow shooting was a limiting factor I already had a second hand D200 but no lens suitable for capturing aircraft in flight I ended up after much hunting through countless reviews with a Sigma (soon renamed by owners as the Bigma) 50-500 APO in fact I still have it, but it took sometime to master this notoriously soft lens in the UK's generally overcast conditions.
Having a lens that lacks stabilisation unlike the newer models means pan shooting at speeds at 200th and under for prop blur takes some getting used to.
Knowing your subject is very advantageous, for example .
The euro fighter, F15 and many modern jet fighters have afterburners and at some point and if the weather is clear they all tend to do a steep reheat climb this is the best time to get a blowlamp shot with lots of flame and heat shimmer. a Stearman or Harvard prop aircraft dont have feathering props so the tips rotate at nearly the speed of sound which inturn means you can still get good prop blur at slightly higher shutter speeds were as with the Corsair its because that plane has a 14 foot propeller even though it can be feathered.
Others like the Spitfire, ME109 or the Wild cat (pictured below) etc need slower shutter speeds of around 160th for that all important blurring
A little bit of internet learning of the aircraft that will be displaying and some camera setting planning before the show can really help get those special shots for your album
My main tips are
1. Put in lots of practice but dont waste time at airshows getting the feel for pan shooting aircraft .
Birds in flight offer a ready resource for flying target practice, seagulls are ideal as they soar quite alot of the time , sparrows are a little too small and go like frantic bats out of hell :D.
2.Get there very early and pick you position at the air show carefully, the best spots are usually already set aside for the press only gang but either end of the display area is better than the middle and at the end of the flight line is the best as the reduction in apparent speed with an aircraft flying slightly towards rather than straight across the camera makes keeping on target much easier.
3. Expose for the aircraft not the sky in the UK generally with my Bigma 1.5 to 2 stops over gives about the best results but with aircraft like the Lancaster of the Battle of Britain flight or the Lysander that are painted black to get detail in the fuselage I have got away with using up to 3 stops over.
Unfortunately ground based aircraft photography has a real problem compeating with those taken from a chase plane but for that you need lots of money or/and very good contacts. However that does not mean you cannot still get some exciting shots even with your feet remaining earth bound.
Lastly some local info for those going to Duxford Flying Legends go on the Friday as well as either the Saturday or Sunday show days many of the aircraft arrive or are test flown throughout the day, the press enclosures are open to all and the crowds are a few hundred instead of 40,000.
Also the entrance fee is normal museum price
oh and while I remember the normal flightline approach (most years) is a banking turn around the back of the tank museum.
PostPosted: Sun Mar 20, 2011 1:40 am
I was surf shooting when this guy popped up over the head land, I had time to get 3 shots off and only one with the full chopper in the frame, no time to slow the shutter down.
PostPosted: Sun Mar 20, 2011 2:52 am
Good to see blue skies have returned to your part of the world 4xxxx. Nice shot.
Brian,
Canon 5DII, 7D, EF-S 10-22, EF 50 USM 1.4, EF-S 60 macro EF 16-35 L USM, EF 24 -15L IS USM, EF EF 100-400L, Canon SX130
PostPosted: Sun Mar 20, 2011 4:44 am
Thanka Brian, down in S.E Qld we have only had a few days of showers since Xmas , most of our rain was at night. No floods or damage here, the flooded area is only 80 km up the road.
PostPosted: Tue May 24, 2011 3:39 pm
For props I use between 1/160 and 1/250. Anything faster freezes it and anything slower makes it too blurry:
For jets, I go 1/1000 or more, depending on light conditions:
Helicopters are the most difficult. You need to shoot at about 1/60, usually with a long lens and without stabilisation or support, getting a sharp picture is very difficult.
EOS 7D + grip, EOS 40D + grip, EOS 10D + grip
EF-S 10-22mm f:3.5-4.5, EF 17-40mm f:4L, EF-S 60mm f:2.8 Macro, EF 70-200mm f:2.8L IS, EF 300mm f:2.8L, EF 500mm f:4L IS, EF 1.4x Converter II
2x Speedlite 550EX
Manfrotto 190XPROB
PostPosted: Tue May 24, 2011 6:14 pm
I agree, choppers are a challenge. However, I got some decent blur on the Coast Guard one here:
http://www.flickr.com/photos/airshowmedianet/
PostPosted: Thu Sep 01, 2011 12:59 pm
nice pics! good you shared them)))
PostPosted: Fri Aug 03, 2012 11:49 pm
Looking forward to my first Air Show assignment.
http://abbotsfordairshow.com/
PostPosted: Sat Aug 04, 2012 4:26 am
Guess we can look forward to some shots.
PostPosted: Sat Aug 04, 2012 2:58 pm
I will be shooting material for the exhibitors and their static displays. Someone else is going to be baking in the sun all day using the BIG glass.
So anything to do with planes in the sky will be on my own time.
PostPosted: Thu Aug 23, 2012 1:34 am
Hi Everyone,
This is my first Air Show.... Nikon D3100 / 70-300 lens........... I do not know all the technical lingo, I just hope you like the picture and all criticism is welcome.
Last edited by Bjorn van Sinttruije on Tue Sep 17, 2013 10:22 am, edited 1 time in total.
Made your image smaller. Please know the maximum dimension should not exceed 1024 pixels.
PostPosted: Thu Aug 23, 2012 1:39 am
Last edited by Bjorn van Sinttruije on Tue Sep 17, 2013 10:21 am, edited 1 time in total.
PostPosted: Wed Oct 23, 2013 5:09 pm
British Midland Embraer ERJ 135 just after landing panned @ 1/50th with the 5D3 and 70-200/2.8L IS II USM
Some flappy mirrors and lots of glass
